Fuel Pump
Old July 15th, 2017, 02:18 PM
Cutlass71s's Avatar
Fuel Pump
Can anyone recommend a good replacement mechanical fuel pump for a 71 350 rocket?
Thank you,
Peter
Cutlass71s is offline
Old July 15th, 2017, 02:32 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Stock AC Delco replacement pump can't be beat...as long as it's not offshore junk. Look at Carter and Edelbrock as well. Just ask what its country of origin is and run from anything thats chineasium.
droldsmorland is offline
Old July 15th, 2017, 02:53 PM
Sadly, most of the new AC Delco replacement parts are not US-made. This is why I stopped using AC oil filters. The quality went right in the toilet when production moved. NOS pumps, while higher quality, unfortunately use rubber parts that are not ethanol compatible.
joe_padavano is offline
Old July 15th, 2017, 03:45 PM
Carter M6108 (no return line) or M6109 (with return line) are the standard pumps sold at most auto parts stores. Checker, O'Reilly, Advance, NAPA, Auto Zone are local sources to check.
Fun71 is offline
Old July 15th, 2017, 05:50 PM
Cutlass71s's Avatar
Thank you
Old July 15th, 2017, 06:42 PM
Cutlass71s's Avatar
Talking
Any tips on replacing it?
Old July 15th, 2017, 10:40 PM
wifespain's Avatar
if the cam eccentric is on the lobe where its pushing the arm down, you will know this when you remove it, disconnect coil wire and bump the starter so you can just put it in and install the bolts. no big deal.
wifespain is offline
Old July 16th, 2017, 04:50 AM
Cutlass71s's Avatar
Thank you
Old July 25th, 2017, 06:26 PM
Cutlass71s's Avatar
Replacement went well, thank you for the help. Had to take all the AC components off to get to the pump but it wasn't that bad. About 50 lbs of crap I kept off but will keep. Runs so much better now.
Old July 25th, 2017, 06:33 PM
Cutlass71s's Avatar
What's a good high flow fuel filter?
Old July 25th, 2017, 09:49 PM
The one you have.
Fun71 is offline
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
mefirst72
February 10th, 2013 06:37 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
sshriber
March 22nd, 2010 06:16 PM
Quick Reply: Fuel Pump
