Telling a 350 from a 260 v8
Old May 8, 2017 | 08:51 AM
midnightleadfoot's Avatar
ph_ckstick1
How would one tell them apart.. ?
In a 1975 Cutlass..
Old May 8, 2017 | 09:10 AM
ROCKETMAN269V's Avatar
Check the casting number at the top front of the block, just below the thermostat housing. 260- 557751; 350- 395558.
Old May 8, 2017 | 10:29 AM
droptopron's Avatar
delete
Drive it & hit the gas, If it goes no place, its a 260
Old May 8, 2017 | 05:09 PM
76olds's Avatar
Hookers under Hood
X2
The 1975 260 would probably have #10 heads rather than the #8 heads for the 1975 350CI
Old May 8, 2017 | 06:12 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
As said above. The 75 350 is a very reliable motor with a lot of performance potential. The 75 260 is also very reliable and has the potential to really hold your boat in place on the water.
Old May 8, 2017 | 06:56 PM
svnt442's Avatar
Pop the air cleaner and look for the Quadrajet that isn't a Quadrajet. The Dualjet that year is a Quadrajet body with the "secondary" top plate just a solid piece of metal with Dualjet on it.
Old May 8, 2017 | 07:29 PM
ph_ckstick1
Thanks guys.
Even if it is a 350 I'm not expecting much from a mid 70's smog motor..
as far as plant you in the seat power..
I'm betting on lame rear gears also.. but it is a solid start so there is that..
Old May 8, 2017 | 08:47 PM
svnt442's Avatar
Originally Posted by midnightleadfoot
Thanks guys.
Well.....it might not be a powerhouse by todays standards, but I put a 75 350 into an 80 and had a ton of fun with that car. I blew the rear end (2.28 open each time) 3 times with no mods to the engine. Now that takes talent.
I finally got a 7.625 3.23 posi in the car and that stopped happening....lol.
Old May 8, 2017 | 11:59 PM
76olds's Avatar
Hookers under Hood
You would be surprised with what a set of duals, timing, carb adjustments,shift kit along with a 3:23-3:42 rear gear will do for a smog 350.
I'm sure you will be happy with it , they are a nice comfortable, fun car to drive either way IMO.
Lots of guys here can give you pointers on how to get the most of what you have to enjoy your ride.
Eric
Old May 9, 2017 | 12:20 AM
ph_ckstick1
Eric
Oh, I'm sure That a few changes could bring some power to it..
I had a 75 in the late 80's it was a rusty pos, but it rode nice..
First I'll go though the basic's.. Then worry about upgrades.
I do want to find a radio/heater ac trim plate that has already been cut for a din radio.. as this one still has the factory radio. and I don't want to cut up the trim parts of the dash for a radio, when I'm sure there are already cut ones out there that people took out to bring it back to oem..
Old May 9, 2017 | 02:59 AM
Redog's Avatar
Yeah the easiest way is the heads. But I like the power test idea
Old May 9, 2017 | 08:31 AM
damaged442's Avatar
Love this...
brownbomber77
Jul 23, 2015 06:17 AM
dedsleds
Aug 25, 2014 10:35 AM
undercar1
Aug 23, 2014 02:43 PM
69ishHoliday
Oct 4, 2013 04:14 AM
ShedrickM
Dec 12, 2012 05:35 AM
