403 stock cam specs
I think if you go to summit and look up a 403 cam, Melling sells a stock replacement so that will have the specs. The duration is very small as is lift. I think it's done on a 114 lsa.
I am no expert but the stock cam was all about smooth idle and emissions. The stock 455 smog cam is better, closer to 200 duration and .435" lift, similar to the Vin 9 307 and early 350 manual trans cam. Talk to Cutlassefi(Mark Remmel), he does many custom cams plus off the shelf. I am getting a custom for my 350 form Mark.
187/200 @ 050 .400 .400 w 1.6
http://www.442.com/oldsfaq/ofcam.htm
562299 36 GM adv 250/264
1968 393859 58 286/286 .472/.472 400 ST ex. OAI
402486 48 262/274 .440/.440 400 AT ex OAI, 350 w/ 269 Pol.
400117 44 258/272 .435/.435 455 Irrig, Mar, hi-comp ex Pol.,
Toro, hi-perf.
400084 36 250/264 .400/.400 350 ex. OAI
402194 82 308/308 .474/.474 350 W-31, Hurst ex CAC Casting #389410
400165 57 285/287 .472/.472 455 Pol, Toro W-34, Hurst CAC
402569 108 328/328 .475/.475 400 OAI after 1-1-68
1969 393859 58 286/286 .472/.472 400 AT, W-32 OAI
400165 57 285/287 .472/.472 455 Pol, Toro W-34, F-85, Hurst,
455 Mar 4BC hi-perf
402486 48 262/274 .440/.440 3269 AT, 350 Pol.
402194 82 308/308 .474/.474 350 W-31 OAI
400117 44 258/272 .435/.435 455 ex. Pol., Toro, hi-perf.
402569 108 328/328 .475/.475 400 OAI ex. W-32
1970 393859 58 286/286 .472/.472 350 4BC ex. AT, OAI, hi-perf
400084 36 250/264 .400/.400 350 2BC, 4BC AT
400165 57 285/287 .472/.472 4257, 67, 4400 AT, Toro W-34
402486 8 262/274 .440/.440 455 Toro ex. W-34
402569 108 328/328 .475/.475 455 4400 ST OAI (W-30)
406768 68 294/296 .472/.472 455 4400 ST ex. OAI
1971 400084 36 250/264 .400/.400 350 2BC, 4BC AT
400117 44 258/272 .435/.435 455 Toro w/2.73 axle, 455 ex 400 or
Perf. Eng.
400165 57 285/287 .472/.472 455 4400 OAI w/AC, 4400 AT
402486 48 262/274 .440/.440 350 4BC ST,455 Toro w/3.07
409691 61 286/287 .474/.472 455 4400 ST, AT OAI ex AC
409717 32 250/264 .400/.400 350 5400
409759 68 294/296 .472/.472 455 4400 ST OAI (W-30)
1972 400084 36 250/264 .400/.400 350 L34, 350 AT L32, 33 All
400117 44 258/272 .435/.435 455 All 4BC AT, Marine LC
402486 48 262/274 .440/.440 350 F-85 4BC ST (L34), Marine
409691 61 286/287 .474/.472 455 L75 ST,L77 AT, Marine HC
409759 68 294/296 .472/.472 455 F-85, 455 ST OAI (W-30)
1973 400084 36 250/264 .400/.400 350 L32, L33, L34
400117 44 258/272 .435/.435 455 AT, Marine, 455 LC
402486 48 262/274 .440/.440 350 ST M15, M20
409691 61 286/287 .474/.472 455 4BC, L77, Marine
1974 409691 61 286/287 .474/.472 455 AG37, 455 W-30, Marine
455 (also #562302)
400117 44 258/272 .435/.435 455 ex W-30, Marine, 455 LC
(Also #562303)
400084 36 250/264 .400/.400 350 (Also #562299)
1975 550638 28 242/250 .396/.400 260
400117 44 258/272 .435/.435 455 (Also #562303)
409691 61 286/287 .474/.472 455 Marine (Reg.)
402486 48 262/274 .440/.440 350 Marine
409759 68 294/296 .472/.472 455 Marine Hi-perf.
1976 550638 28 242/250 .396/.400 260
402194 82 308/308 .474/.474 455 Marine Hi-perf. F.P.
409691 61 286/287 .474/.472 350 and 455 Reg. Perf. Marine
400117 44 258/272 .435/.435 455 All, Irr., ex Marine
1977 562298 52 256/277 .247/.250 260 (thru 1982)
562299 36 250/264 .400/.400 350, 403 (thru 1980)
562301 68 294/296 .474/.472 403 Hi-perf. Marine thru 79
562302 61 286/287 .472/.472 350, 403 Reg. Perf Marine, ST thru 79
joepenoso
Sep 12, 2015 01:40 PM
odddoylerules
24
Jan 22, 2014 06:35 AM
