When to do compression testing
Old Feb 29, 2016 | 07:21 AM
AJFink's Avatar
I should know this but age and time has taken my memory again.
To get a good feel for condition should I take them cold and at normal temp.?
I have a 350 with #8 heads (don't know the type of pistons yet) The motor has been replaced (says prior owner) about 10,000 miles ago. What should I be seeing as far as compression?
Old Mar 1, 2016 | 05:15 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Warm, throttle wide open and all plugs removed with the ignition disconnected. My stock internal #8 headed 350 with a Performer cam had 140-142 psi all 8 cylinders. It also has 15-20 psi hot idle oil pressure, 45-50 cruise and 60 cold oil pressure. Put an oil gauge on it as well. I have found the mid 70's 350's very reliable and adequate power, especially for their time. It was a 75 Cutlass 4 door, 350 Rocket powered that our family owned that turned me on to Oldsmobile's.
Old Mar 1, 2016 | 07:51 AM
You can also do the test dry, and then add a couple of squirts of oil in each cylinder and repeat to determine if the rings are bad. Leak down tests are a good trouble shooting aide if your trying to isolate cylinder issues also.
Old Mar 1, 2016 | 01:27 PM
jaunty75's Avatar
I usually do it on Thursdays.
Old Mar 1, 2016 | 03:03 PM
For a factory engine, what olds 307 and 403 posted sounds right. Be aware that cylinder pressure is controlled not only by the static compression ratio of the engine but also by the camshaft profile. This means two engines with the same CR but different camshafts can have drastically different pressure readings.
Without knowing what pistons or camshaft are in there you should be looking for consistent readings from cylinder to cylinder.
Old Mar 1, 2016 | 03:23 PM
AJFink's Avatar
Like it LOL!!! ........ A little humor goes a long way when your restoring one of these babys!
Old Mar 9, 2016 | 02:24 PM
AJFink's Avatar
My compression test results
I did my compression test before the teardown. Stone cold WOT all cylinders average 145 psi. lowest 140 highest 150 . Could not do a test with it warm. So for a remanufactured engine was said it had about 10,000 miles on it. The gauge I had was not the best but was a screw in. How do these numbers sound?
Old Mar 9, 2016 | 04:53 PM
Sounds good for a fresh low compression engine.
greenslade
Mar 29, 2011 03:56 PM
mavrick70004
Nov 12, 2008 10:46 PM
TheRuss
Feb 1, 2008 09:04 PM
Chumley
Jan 21, 2007 01:30 PM
