Water pump for a Rallye 350
Old Dec 24, 2020 | 12:40 PM
Federated52's Avatar
Ok, got the brake issue situated. Works great now. Now I noticed the water pump leaking, my question is: There are two listed on rockauto.com one has a 5.1" hub height, and the other is 5.572" hub height. Is there a standard size they used on the "Rallye's"? From what I measured it looks like it would be the 5.1", but I don't want to order the wrong height. Where do I measure from. I measured from the flat part of the pump to the outside hub of the pulley. Thanks in advance for any help.
Old Dec 24, 2020 | 12:54 PM
Ryans F85's Avatar
Seeker of knowledge
I think you have thread jacked this enough. Maybe start Another thread.
Old Dec 24, 2020 | 01:06 PM
Ok, sorry. I will start another.
Old Dec 24, 2020 | 01:10 PM
Water pump height question.
I noticed the water pump leaking on my '70 Olds Rallye, my question is: There are two listed on rockauto.com one has a 5.1" hub height, and the other is 5.572" hub height. Is there a standard size they used on the "Rallye's"? From what I measured it looks like it would be the 5.1", but I don't want to order the wrong height. Where do I measure from. I measured from the flat part of the pump to the outside hub of the pulley. Thanks in advance for any help.
Old Dec 24, 2020 | 01:25 PM
The different sizes were AC and non-AC applications. The height is measured from the mounting face to the top of the hub.
There is a "sticky" with this info:
https://classicoldsmobile.com/forums...lengths-28191/
Old Dec 24, 2020 | 01:27 PM
4Speedy's Avatar
It's probably what you measured.
which pulley do you have on your pump?
Should be a 2 letter code on the face of the pulley.
Plus if it's the original pump they can be rebuilt for around $100. Then you know it'll fit and you get to keep it original.
Old Dec 24, 2020 | 02:19 PM
Here, I moved them for you. Asking a water pump question in a brake forum probably isn't your best choice...
Assuming your engine has the stock accessory brackets, a 1970 350 uses the 5.1" pump for non-A/C applications and the 5.6" pump for A/C applications. If there is any doubt, pull off the pulleys and measure from the pulley mounting surface on the pump flange to the gasket surface. There are actually three different Olds water pump lengths. That's 6.1" on the left, 5.6" in the middle, and 5.1" on the right.
Old Dec 24, 2020 | 02:26 PM
This diagram is misleading, as it ONLY applies to the 1970-72 cars. Other years are different. For example, on my 67 Delta, the pumps are 5.1" for both A/C and non-A/C applications.
Old Dec 24, 2020 | 07:52 PM
Thank you everyone, It is non-A/C car. Sorry don't know what pulley is on it. Haven't pulled it off yet. If I think of it I will let you know what I find out.
Sorry about the cooling question in the brake forum, must be too much Christmas spirit.
Merry Christmas & Happy New Year everyone.
Old Dec 25, 2020 | 04:47 AM
Hey fed, if that water pump you are taking off is the original, I would at least keep it. The last water pump I bought for a 350 Olds was a Chinese blob. Worked ok but no original numbers, etc. Merry Christmas to you also!!!
Old Dec 31, 2020 | 10:12 AM
Hi everyone,
First, I would like to wish everyone a Happy New Year. Hopefully it will be a lot better than 2020, and we can back to car shows, flea markets, cruise nights, ect.
Second, sticking with my post, I am thinking about getting the water pump rebuilt, instead of getting an aftermarket one. I live around southeast PA (About an hour NW of Philly). Does anyone know of anybody who can rebuild it around my area.
Thanks for all the help & advise.
Old Jan 1, 2021 | 04:33 AM
That is a good idea.
Federated52
Dec 24, 2020 01:27 PM
user 7408240824
Mar 21, 2019 04:45 PM
Torqueline
Tech Editor's Desk
Feb 4, 2018 05:31 AM
Dave Siltman
Jul 13, 2014 01:27 PM
1968_Post
Sep 13, 2013 06:29 AM
