W31 Intake and Aluminum Heads
I'm not 100% sure, but the aftermarket heads that I know of are primarily designed for big blocks. If there are specific small block aluminum heads they are new to me. By the way, how much WAS that NOS W-31 intake?I read the thread on your restoration- you do some fine work and should be proud of both yourself and your car.
The only issue will be port-matching the intake to the larger ports on the E-brock heads. Otherwise, no problems. Well, there is the issue of the fuel pump not clearing the E-brock heads on the lower deck SBO, so you'll need to run an electric pump.
rcdynamic88
October 20th, 2014 11:28 AM
RATCHETMASTER
October 29th, 2011 06:27 PM
svnt442
July 17th, 2011 04:43 PM
