W31 Intake and Aluminum Heads
Old Jun 24, 2012 | 04:06 PM
oldzzy's Avatar
wait.... what....
Can a W31 intake be used with aluminum heads? I know there would have to be machining, just wanted to know if it's even possible.
Old Jun 24, 2012 | 04:53 PM
Dave Siltman's Avatar
I'm not 100% sure, but the aftermarket heads that I know of are primarily designed for big blocks. If there are specific small block aluminum heads they are new to me. By the way, how much WAS that NOS W-31 intake?I read the thread on your restoration- you do some fine work and should be proud of both yourself and your car.
Old Jun 24, 2012 | 05:03 PM
oldzzy's Avatar
wait.... what....
Yes they are Edelbrock heads. I picked up the intake for $750, and thnx for the compliment on my build.
Old Jun 25, 2012 | 06:52 AM
The only issue will be port-matching the intake to the larger ports on the E-brock heads. Otherwise, no problems. Well, there is the issue of the fuel pump not clearing the E-brock heads on the lower deck SBO, so you'll need to run an electric pump.
tocicar8825
Sep 21, 2021 07:10 AM
rcdynamic88
Oct 20, 2014 11:28 AM
Radarman68
Dec 21, 2012 10:28 AM
RATCHETMASTER
Oct 29, 2011 06:27 PM
svnt442
Jul 17, 2011 04:43 PM
