two piece intake gasket vs. Valley pan intake gasket
Old May 29, 2016 | 08:06 AM
86GutlessCutlass's Avatar
I think my intake gaskets are leaking around my egr ports on my intake I've never had trouble with the valley gaskets before. But I also wanted to try the two piece gasket set at some point does any one have any pros or cons of the two piece intake gaskets?
Old May 29, 2016 | 09:33 AM
Two piece gaskets can be either metal the same as the valley tray or composition material. I have used several varieties of the composition gaskets and all have worked well. I never used the Fel Pro metal two piece gaskets but they should be the same as the valley tray, just without the center tray.
Old May 30, 2016 | 08:58 AM
coppercutlass's Avatar
Chevy budget Olds powered
The metal shims 2 piece work great. Although many guys frown upon it. I do a very and i mean very light coat of high temp rtv on the outside of the crush rings on them. Thats all i have ever succesfully used. The composite fiber ones for some reason leave my end rails a little too open and it leaks oil even with huge beads of rtv . The metal ones are thinner so it closes up the gap on the end rails. I know it could be user error on my end but thats just my experience.
Almond900
May 29, 2016 08:03 PM
VI Cutty
May 24, 2015 11:28 AM
getitmann
May 25, 2012 08:40 PM
ddx77
Jun 14, 2010 07:37 AM
Flye
May 12, 2009 05:30 PM
