torrington bearing
Old May 15, 2010 | 07:32 PM
dman0712's Avatar
torrington bearing
I was going to install a torrington bearing on my 403 to keep the new hydraulic roller cam from walking. My engine is already together so id rather not take it apart to machine the block for the bearing or do you not have to take the engine apart to do this? I dont know how the machine shops go about this. My other question is if i can just remove the camshaft and machine a step in the end of the cam for the bearing to fit in?
Old May 15, 2010 | 07:48 PM
cutlassefi's Avatar
Why are you going thru the trouble to do this after the fact?
Old May 15, 2010 | 09:53 PM
dman0712's Avatar
because i bought the brass spacer and thrust button from mondello but its is currently making the lifters ride closer to the edge of the cam lobe.
Old May 16, 2010 | 07:17 AM
cutlassefi's Avatar
O.K. if I get you right, you're going to replace the brass spacer with the torrington? What will that accomplish? Just let the cam ride on the block, then set your endplay with the button.
Old May 16, 2010 | 08:17 AM
dman0712's Avatar
wont the cam eat into the block?
Old May 16, 2010 | 10:26 AM
cutlassefi's Avatar
No, you have to remember a roller will do so even less. The lobes aren't ground to make the cam push rearward like on a flat tappet. Plus you should have plenty of oil coming out if the front cam bearing to lube the area.
Normally I drill a .030 hole thru the oil galley in the face of the thrust surface for the cam if it's a flat tappet. That'll help but it's really not necessary, especially on a roller.
Old May 16, 2010 | 03:03 PM
dman0712's Avatar
ok i took the spacer off the cam and put the cam back in to see how the rollers were lined up with the lobe centerline. Its a little better. Does it have to be exactly in the middle? Id say judging by looking that the the lifter is about 1/16 of an inch from being center.
Old May 16, 2010 | 06:24 PM
cutlassefi's Avatar
No it doesn't. Just make sure you don't have excessive end play and you'll be fine.
Old May 16, 2010 | 06:32 PM
dman0712's Avatar
ok. i have the brass thrust bearing. should i use that or should i get the torrington one with the bearings?
Old May 17, 2010 | 05:40 PM
cutlassefi's Avatar
Based on the info given it seems the block surface is o.k. cuz it's making the cam off center. So why are you using any spacer?
Old May 17, 2010 | 05:53 PM
dman0712's Avatar
im not using a spacer its the thrust bearing that goes on the end of the cam bolt to prevent cam walk. Right now there is nothing between the cam and block
Old May 17, 2010 | 05:55 PM
dman0712's Avatar
my problem is with no spacer the cam is still slightly off the lobe centerline. Wont that effect my timing? I dont know what to do here
DonFrost
Aug 27, 2009 12:55 PM
Flye
Drivetrain/Differentials
Jul 30, 2009 10:24 AM
Bunser
Apr 21, 2008 03:12 AM
Topless72
Apr 9, 2008 11:47 AM
J'ville
Sep 4, 2007 09:50 AM
