Ticking sound identification
Ok so fresh build just breaking it in. Have the comp 1441 rockers which I hear can be noisy. Also have headers which could be ticking. It doesn't go away when the engine warms up which makes me think valve train. I guess the only way to know is pull the valve covers and inspect while running. But should I expect a certain amount of tick from these valve trains? I've only ever run a stock valve train.
Oh and I didn't block the heat crossover in my rpm intake. I also read that those can tick? Anyone confirm that?
It wouldn't let me attach the audio but you can copy and paste this into a web browser.
https://drive.google.com/file/d/17cPvTw3TaDpL7C1zUX1bhBwtSpoVREfy/view?usp=drivesdk
Thought?
Thought?
I agree that the lifter preload is a suspect.
My car has those rockers and headers and there aren’t any unusual noises from them.
And I see no way the exhaust crossover in an aftermarket intake manifold would be any different than a factory manifold.
What's the thoughts on adjusting these running vs cold
Fixed the link should work now. It was a permission thing
https://drive.google.com/file/d/17em...w?usp=drivesdk
https://linksharing.samsungcloud.com/LIstJBCAxcVN
https://linksharing.samsungcloud.com/L7HTmM6T0xkN
The first pushrod seems to be traveling or wandering around. Is this thing bent
In the slowmo vid it sure sounds to me like that loud clicking is in time with that first rocker.
What can and lifter set. I have had 2 comp cams with just noisy lifters. They needed a little more than half turn to quiet them down. Another thing you should check for is lift clearance at the valve. I broke a rocker arm and bottomed it out on the valve stem boss on the cylinder head because a lifter stuck up and minimal lift clearance.
