Ticking sound identification
Old Jul 21, 2020 | 07:07 PM
glamaina's Avatar
Ok so fresh build just breaking it in. Have the comp 1441 rockers which I hear can be noisy. Also have headers which could be ticking. It doesn't go away when the engine warms up which makes me think valve train. I guess the only way to know is pull the valve covers and inspect while running. But should I expect a certain amount of tick from these valve trains? I've only ever run a stock valve train.
Oh and I didn't block the heat crossover in my rpm intake. I also read that those can tick? Anyone confirm that?
It wouldn't let me attach the audio but you can copy and paste this into a web browser.
https://drive.google.com/file/d/17cPvTw3TaDpL7C1zUX1bhBwtSpoVREfy/view?usp=drivesdk
Thought?
Old Jul 21, 2020 | 07:52 PM
coppercutlass's Avatar
Chevy budget Olds powered
File was no good for me. But how much lifter pre load is there ?.
Old Jul 21, 2020 | 09:44 PM
I agree that the lifter preload is a suspect.
My car has those rockers and headers and there aren’t any unusual noises from them.
And I see no way the exhaust crossover in an aftermarket intake manifold would be any different than a factory manifold.
Old Jul 22, 2020 | 03:58 AM
glamaina's Avatar
That's next for me to check. Just took the valve covers off last night it was too late for me to be running my car so I'm going to check today.
What's the thoughts on adjusting these running vs cold
Fixed the link should work now. It was a permission thing
Old Jul 22, 2020 | 08:31 AM
glamaina's Avatar
Shot avideo with the covers off. I hear most of the noise from valve 1. When I get the microphone next to it you can hear it good. This won't let me post the video but here is a link
https://drive.google.com/file/d/17em...w?usp=drivesdk
Old Jul 22, 2020 | 09:57 AM
I have always adjusted with the engine not running and never had any problems.
Old Jul 22, 2020 | 12:56 PM
Half turn past zero lash. Roughly .040
Old Jul 25, 2020 | 09:24 AM
glamaina's Avatar
https://linksharing.samsungcloud.com/LIstJBCAxcVN
https://linksharing.samsungcloud.com/L7HTmM6T0xkN
The first pushrod seems to be traveling or wandering around. Is this thing bent
Old Jul 25, 2020 | 10:02 AM
RetroRanger's Avatar
72 Olds CS
I couldnt see it in the first vid tho it was a good vid, the second video tho it sure looks like it might be bent, is that where the clicking is?
Old Jul 25, 2020 | 10:05 AM
glamaina's Avatar
Its harder to see in slow mo. The loudest clicking is coming from there but they are all clicking. I used a hose to my ear. Debating trying to tighten then slightly while running.
In the slowmo vid it sure sounds to me like that loud clicking is in time with that first rocker.
Old Jul 25, 2020 | 01:53 PM
72 Olds CS
Just pull that pushrod out and put it on a flat surface and roll it, if its bent you will know right there.
Old Jul 25, 2020 | 03:05 PM
What can and lifter set. I have had 2 comp cams with just noisy lifters. They needed a little more than half turn to quiet them down. Another thing you should check for is lift clearance at the valve. I broke a rocker arm and bottomed it out on the valve stem boss on the cylinder head because a lifter stuck up and minimal lift clearance.
Old Jul 25, 2020 | 07:46 PM
glamaina's Avatar
I know they are topline lifters that's all. Turns out the first rod was bent. Straightened out it best i could for now. That one quieted down however they are all ticking. I'd say it's like the sewing machine sound. I'm starting to think maybe the rods are to short.
louie
Mar 4, 2020 04:27 PM
Kyle's 77 Cutlass
Jan 18, 2014 08:47 AM
abram
Nov 10, 2009 10:18 AM
unrelatedbrothers
Jun 29, 2009 02:36 PM
cts-v
Feb 25, 2009 02:32 AM
