swap?
Yes, if you want to drop compression by 1 to 1. The two sets of 76 #8 heads I measured were 77 to 78cc. Your #2 heads will be at least 10cc smaller. Plus there is a restriction under in the bowl under the exhaust valve. Once removed, they will flow similar to your current heads. As is, definitely less on the exhaust side.
