swap?
Old Nov 30, 2021 | 10:15 AM
65-330's Avatar
swap?
Will 350 heads out of a 76 olds work on a 65 330?
Old Nov 30, 2021 | 12:08 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes, if you want to drop compression by 1 to 1. The two sets of 76 #8 heads I measured were 77 to 78cc. Your #2 heads will be at least 10cc smaller. Plus there is a restriction under in the bowl under the exhaust valve. Once removed, they will flow similar to your current heads. As is, definitely less on the exhaust side.
Old Nov 30, 2021 | 02:36 PM
This swap would be just the ticket if you planned to run a turbo or two.
Old Dec 2, 2021 | 05:37 AM
brownbomber77's Avatar
It's not a good idea....at all... Only use 64-67 330 heads as they have the smallest combustion chambers. #2 and early #3 were made for 45* bank angle, late #3 and all #4 are for 39* bank angle.
Old Dec 2, 2021 | 05:39 AM
65-330's Avatar
Thanks, i'm going to redo my 330 heads.
Old Dec 2, 2021 | 06:57 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Good move.
jmos4
Jul 17, 2018 02:19 PM
blaker1
Dec 17, 2014 05:32 PM
import extermination
Oct 3, 2011 06:38 AM
65cutty
Jun 25, 2009 05:44 AM
65cutty
Aug 27, 2008 10:09 AM
