Starter mount holes
Old Feb 17, 2025 | 11:04 PM
back2life's Avatar
Starter mount holes
I have an 350 engine and tranny that I acquired for damn near free for my 77 delta. Starter sounded back cranking up but runs good. I took starter down and one bolt was just sittin there so I find out the hole was damaged and they had tried to helicoil it but it was crooked I put in a new helicoil. My question is there a more permanent type of repair that can be done to the holes that will last?
Old Feb 18, 2025 | 04:03 AM
BillK's Avatar
If you put a new helicoil in and the bolt will tighten down properly then I would not worry about it. Once it is in place it really should not move. They do make oversize inserts but there is not a lot of metal around the starter holes so I am not sure if I would take a chance with that.
Old Feb 18, 2025 | 05:09 AM
Be sure you are using the strap at the forward end of the starter. The 800 lb Delco starter puts a significant strain on the mounting bolts if you leave that strap off.
Old Feb 18, 2025 | 08:36 AM
OLDSter Ralph's Avatar
This may seem like a small thing, but make sure the "tail" of the Heli-coil is one thread below the surface or and champfers.
Old Feb 18, 2025 | 07:10 PM
back2life's Avatar
what is this strap you are referring to? Do you happen to have a pic of it or how it attaches?
Old Feb 19, 2025 | 04:02 AM
Dynoking's Avatar
If the bolts that attach the starter are replaced, make sure that they are starter bolts which have wider shanks and not plain hardware bolts.
Old Feb 19, 2025 | 06:53 AM
HydraMatic's Avatar
Old Feb 19, 2025 | 07:35 AM
BillK's Avatar
https://www.inlinetube.com/products/...b2d3526c&gQT=1
BSiegPaint
Jun 15, 2021 11:33 AM
snail
Mar 18, 2017 09:13 AM
jnosich
Mar 4, 2015 04:41 PM
Blk71SX
Mar 23, 2010 06:46 PM
redvettemike
May 31, 2009 04:47 PM
