Starter mount holes
Starter mount holes
I have an 350 engine and tranny that I acquired for damn near free for my 77 delta. Starter sounded back cranking up but runs good. I took starter down and one bolt was just sittin there so I find out the hole was damaged and they had tried to helicoil it but it was crooked I put in a new helicoil. My question is there a more permanent type of repair that can be done to the holes that will last?
If you put a new helicoil in and the bolt will tighten down properly then I would not worry about it. Once it is in place it really should not move. They do make oversize inserts but there is not a lot of metal around the starter holes so I am not sure if I would take a chance with that.
BSiegPaint
Jun 15, 2021 11:33 AM
