to soak or not to soak....lifters
Old November 27th, 2013, 03:11 PM
Macadoo's Avatar
New hydraulic lifters with new cam. Do you folks soak them in oil before install? I've read some even pump them with a push rod to get 'em full. Or just let the priming of the oil system do it's thing?
Opinions?
Macadoo is offline
Old November 27th, 2013, 03:36 PM
wgonzo64's Avatar
I soaked my lifters for several days before I installed them
wgonzo64 is offline
Old November 27th, 2013, 03:40 PM
Standard procedure - even in the CSM's. Absolutely soak em and soak em good. You also coat your head bolts before installing them to get the proper torque reading when tightening.
Allan R is offline
Old November 27th, 2013, 03:45 PM
Octania's Avatar
Motor oil or assembly lube in lifter bores
cam breakin lube on cam and lifter base.
Assm. Lube in pushrod cup [and all other wear points in the valvetrain]
During oil pump priming, which the CSM does not refer to, all air will be chased out of the lifters within seconds.
No need to soak the lifters if alternate procedures take care of that issue.
Octania is offline
Old November 27th, 2013, 04:10 PM
Macadoo's Avatar
Thanks for the thoughts guys. It's 2 to 1 for, although I'm leaning towards Octania which makes it a tie. More opinions?
Macadoo is offline
Old November 27th, 2013, 04:16 PM
dc2x4drvr's Avatar
Don't soak, not necessary.
What Octania said.
dc2x4drvr is online now
Old November 27th, 2013, 04:20 PM
Chevy budget Olds powered
coppercutlass's Avatar
I dont soak mine but that because I set the valve lash on my adjustable rockers before firing up the engine since the engine has non adjustable rockers It wouldn't hurt to sok. the only reason I don't soak is to set valve lash.
coppercutlass is offline
Old November 27th, 2013, 06:50 PM
Just the facts...
BILL DEMMER's Avatar
soak them and pump them a few times, it can't hurt anything to have lube immediately. and, use assembly lube as suggested above. there's no such thing as being too careful.
bill
BILL DEMMER is offline
Old November 27th, 2013, 07:40 PM
car guy
gearheads78's Avatar
Don't worry about soaking just prelube the motor.
gearheads78 is offline
Old November 27th, 2013, 08:03 PM
Old School Olds
tru-blue 442's Avatar
Originally Posted by gearheads78
don't worry about soaking just prelube the motor.
+1
tru-blue 442 is offline
Old November 27th, 2013, 08:10 PM
Macadoo's Avatar
Lol, well...that's 4 for and 4 against. Not exactly a landslide. Starting to look like either way is good.
Macadoo is offline
Old November 27th, 2013, 08:14 PM
I still like to soak them overnight before assy, what does it hurt. Make when you prime the engine that you have oil flowing through all the push rods onto the rockers.
oldcutlass is online now
Old November 28th, 2013, 12:09 AM
'87 Delta 88 Royale
rustyroger's Avatar
If the lifters fill with oil you'll find the valves wont close properly. If soaking doesn't make this happen oil hasn't got into the lifters.
Prime the engine in the normal way and you have lube round the lifters which will rapidly take in the oil they need to eliminate lash after startup.
Roger.
rustyroger is offline
Old November 28th, 2013, 01:41 AM
Agreed. Soaking is the equivalent of gravity bleeding brakes whereas oil priming is akin to pressure bleeding the brakes. Ten seconds vs. overnight. Which sounds more efficient to you?
Fun71 is offline
Old November 28th, 2013, 06:17 AM
No need to soak 'em, but they should be all lubed up nicely with assembly lube.
As others have said, when you pre-lube the engine with your ½" drill, ¼" extension, and 5/16" socket, you will push oil into the lifters, then when you first crank the engine, the lifters will pump up.
Just like when you've got a momentary drop in oil pressure (surely you've had a car when you were younger where you knew it was time for a quart or two when you made a left turn and the lifters clattered...) and a lifter ticks, but then you get pressure back and the tick goes away in about two seconds. There's no harm in running the engine with the lifters not pumped up - the valves just don't open as far for a few seconds.
It won't hurt to soak them, if you want to, but it's an extra step that is not necessary.
MDchanic is offline
Old November 28th, 2013, 06:22 AM
Lars's Avatar
what really matters is cam lobe lube on the lifters, or cam breakin in lube on the lifters. did you grease the cam before you installed it with the propper breakin grease? the lifters will get filled when you prime the system. when your primeing the motor turn it over a few times.
Lars is offline
Old November 28th, 2013, 09:10 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I always soak them, what does it hurt? What size cam did Mark spec you?
olds 307 and 403 is online now
Old November 28th, 2013, 11:31 AM
Proud Viet Nam Veteran
redoldsman's Avatar
Maybe putting them in oil and priming them might work but I really don't see where soaking them will do any good. They are made of steel and the oil is not going to soak into the steel. This is not a turkey or piece of meat we are marinating over night. I just find it funny talking about marinating valve lifters. I think the cam lube is the most important thing.
HAPPY THANKSGIVING EVERYBODY
redoldsman is offline
Old November 28th, 2013, 03:27 PM
380 Racer's Avatar
When I had adjustable pushrods on my build(s) I used a gapping tool to set the lifters. I could not have any oil in the lifters when I set them so no soaking just cam lube and priming after they were set.
380 Racer is offline
Old November 28th, 2013, 04:37 PM
M-14's Avatar
Soaking lifters in oil can make them act like solid lifters briefly, like when your trying to get a fresh engine started. This could be a problem on olds engines, the stock valvetrains that you just torque down the rocker nuts. It could cause the valves to hang open. If you soak them, it is a good idea to plunge the lifters a dozen times.
M-14 is offline
Old November 28th, 2013, 05:07 PM
MOTORHEAD
11971four4two's Avatar
zip
11971four4two is offline
Old November 28th, 2013, 05:18 PM
captjim's Avatar
You are the second person to suggest this, along with rusty roger. Not sure about this? Even if the lifter is full, once any pressure is applied, oil will go up the pushrod, won't it?? That would relieve the pressure, not open the valve??
All soaking the lifters does is make a mess. It also makes applying cam lube to the bottom of the lifter (as others stated, the most important part) more difficult and messy. IMHO.
captjim is offline
Old November 28th, 2013, 05:21 PM
jensenracing77's Avatar
I quit soaking my lifters. I tried it several time and NEVER had them fill with oil. I just prime the engine with a drill now.
jensenracing77 is offline
Old November 28th, 2013, 06:54 PM
Macadoo's Avatar
It took the entire packet of Joe Gibbs for the cam (which came with the cam), it wasn't very much. Do I have to use the exact same break-in lube on the lifters? I was looking at the Lucas break-in lube from Autozone because it's described as "tacky" like the Gibbs. Or should I order the Gibbs online and wait?
Macadoo is offline
Old November 28th, 2013, 06:58 PM
The lucas stuff is in a little 6 oz 4oz bottle. the break in oil additive is in a 12 oz 14r oz bottle. If autozone does not have it I think napa stocks the permatex hightack red assembly lube. I have used the lucas stuff on all my builds. No flat cams yet. Although any assembly lube will work . I buy what's available on the shelf.
Old November 28th, 2013, 07:02 PM
Macadoo's Avatar
Thanks Copper, but can I mix them? One brand on the lobes and another on the bottom of the lifters? I think that's my real question?
Macadoo is offline
Old November 28th, 2013, 07:05 PM
I did it before I see no harm . usually I use like 2 bottles between the bearings , and cam. And I dab a drop on the tips of the rockers. I once used red high tack and the lucas when the local napa was out that's actually how I found the lucas . I find it to be super tacky compared to others maybe I'm biased .
Macadoo's Avatar
Permatex Ultra Slick Engine Assembly Lube? Advance has it.
Macadoo is offline
Old November 28th, 2013, 07:06 PM
Yeah. I think we found out I'm not good with names but I give enough info lol. I forget names of little things like that lol.
Old November 28th, 2013, 07:28 PM
Macadoo's Avatar
Sounds good dude. You just saved my weekend. I didn't like the thought of spending my time off waiting for an internet order.
Macadoo is offline
Old November 29th, 2013, 12:45 AM
  #31
'87 Delta 88 Royale
rustyroger's Avatar
Full lifters won't squirt out excess oil in a few turns of the camshaft, they are designed to leak very slowly, if they didn't you would have lifter clatter every morning.
Oil will be round the cam & lifters almost immediately after startup, break in lube for your new cam & lifters is key to long life for them.
Roger.
Old November 29th, 2013, 06:53 AM
  #32
Run to Rund's Avatar
If you want to fill the lifter with oil, put it into a cup with the oil level above the top of the lifter, use a pushrod to depress the plunger several times.
Run to Rund is offline
Old November 29th, 2013, 10:46 AM
  #33
Lars's Avatar
I seen your other thred, if you want to soak, i like runs idea. And any cam brake in lube should be fine. Good luck
Lars is offline
Old November 29th, 2013, 12:44 PM
  #34
Macadoo's Avatar
Thanks Lars...
Macadoo is offline
Old November 29th, 2013, 01:39 PM
  #35
jfb
jfb's Avatar
just my 2 cents worth. I soaked mine used a additive for zinc and pre lubed my engine and had 0 problems afterwards.
jfb is offline
Old November 29th, 2013, 03:17 PM
  #36
Sampson's Avatar
This is kinda on the same subject. Does anyone premix their oil additive with the oil before putting it in the engine? It seems to me that if you add it to the oil in the car there will be a period of time the engine will run before the additive and oil get mixed well.
Sampson is offline
Old November 29th, 2013, 03:19 PM
  #37
I usually do my 6 quarts then the additive from lucas as they instruct then pre lube.
Old December 1st, 2013, 07:05 AM
  #38
Macadoo's Avatar
So Copper, you feel the pre-lube mixes in the additive before you fire it up? How long do you pre-lube, just until you see oil at the rockers? Or longer?
Macadoo is offline
Old December 1st, 2013, 07:48 AM
  #39
Once I see oil from the rockers I keep spinning it for a minute or two. It might take a while for the oil to get out of all the pushrods. On my last engine. That's currently in my 72 I pre lubed it but the lifters still ticked for like half a minute while they filled up but no harm no foul everything is good . Yes the lucas zddp additive specifies that druing break in you used your needed amount of oil them the additive. Then for everyday use include it to the needed amount of oil so that you don't run more oil than you need to if that makes sence.
Old December 1st, 2013, 05:44 PM
  #40
Macadoo's Avatar
Thanks for the info Copper.
Macadoo is offline
jimmypthatsme
June 18th, 2014 09:34 AM
mmurphy77
August 11th, 2013 05:35 PM
davepnola
October 16th, 2011 02:37 PM
scubastever
August 30th, 2011 06:17 AM
silverriff
March 4th, 2010 09:50 AM
Quick Reply: to soak or not to soak....lifters
