long crank, hard start after hot soak
Old August 29th, 2011, 07:51 PM
this is not my car lol
scubastever's Avatar
1967 442
400 CI
symptoms:
after a hot soak, the engine cranks a long time before starting. i find pumping the gas 5 or 6 times helps but this isnt normal.
during hot soak, fuel seems to be draining back to the tank. the draining back lasts about 5 minutes.
check out the video:
http://www.youtube.com/watch?v=9Q2YbLAdcoY
has anyone else seen this phenomenon ?
scubastever is offline
Old August 29th, 2011, 08:22 PM
ah64pilot's Avatar
I had that problem...the fuel pump was the problem. The diaphragm was weak or something. Changed the mechanical pump for $17 and problem was solved.
Anyone else have different experiences?
ah64pilot is offline
Old August 29th, 2011, 08:23 PM
ah64pilot's Avatar
PS, another thing I noticed was that the filter (exact same as what you've got in your video) was loose. I took the hose off one end and tightened it up a bit and it held pressure much better after.
Old August 29th, 2011, 09:53 PM
Jaybird's Avatar
Yup, What ah64pilot said. I replaced the fuel pump and tightened the fitting at the carb.
Jaybird
Jaybird is offline
Old August 30th, 2011, 06:10 AM
thanks guys!
Old August 30th, 2011, 06:17 AM
citcapp's Avatar
Get rid of the glass filter they are prone to leaking and/or breaking and go to a all metal fuel filter unless you want a fried Olds which is not a pretty site. I have seen this in more then one instance.
citcapp is offline
ej69
April 25th, 2023 11:56 AM
Macadoo
December 1st, 2013 05:44 PM
mmurphy77
August 11th, 2013 05:35 PM
etohboy
June 1st, 2009 08:07 AM
cbogartjr
July 21st, 2008 11:31 AM
Quick Reply: long crank, hard start after hot soak
