Should fan spin freely 72 350
Old Oct 27, 2019 | 01:45 PM
Oldssupreme's Avatar
Chris
Hi! I'm almost to the point of starting her up. Just curious as to whether or not the fan should spin freely by hand? I can spin the fan fine, but it does not continue spinning after I let my hand go. There is a new thermal clutch on it, new water pump, new belts, new hoses etc As I mentioned, I have not started it up yet since I installed all this. Does this sound like an issue?
Old Oct 27, 2019 | 02:12 PM
don71's Avatar
same but different
That sounds normal to me. There is a viscous fluid in the center piece that is part of the thermal clutch operation.
Old Oct 27, 2019 | 02:17 PM
Chris
Thank you Don.
CRUZN 66's Avatar
Olds Fever
Shouldn't be an issue... Sounds like the new clutch you installed is doing what it is designed to do...
Chris
Ok, thanks! Last time I change the clutch was 1996 so I don't quite remember. Thank you both.
Old Oct 27, 2019 | 05:10 PM
Was the car up on jack stands when you installed the shroud? If it was you might want to check for clearance on the fan when it's sitting on the ground. That may have changed slightly. Don't ask how I found this out....
Old Oct 27, 2019 | 05:34 PM
Chris
Allan it's funny you say that because as matter of fact yes it was up on jackstands and I AM having issues with the fan contacting the bottom of the shroud and I was too embarrassed to ask about it. If I get underneath and push the bottom of the shroud toward the front of the car it clears the fan blades but I don't see a way to adjust it to "stay" in that position. What are you thoughts and your experience? Thanks Allan!
Chris
Old Oct 27, 2019 | 08:00 PM
On my car I put some spacers between the upper shroud mounting bolts and the radiator top plate.
Old Oct 28, 2019 | 03:08 AM
Chris
Fun71, so that forced the shroud down to help the blades clear the bottom of the shroud?
Old Oct 28, 2019 | 06:38 AM
Chris, what Kenneth said. The Assembly Manual states to "shim as needed" to get the necessary clearance. In my case it's 3 shims on each side of the shroud top. You might also want to see if you can bend the mounting tabs on the bottom of the shroud a bit? It might not be easy to get those bolts that hold the shroud in place though.
The reason the shroud is hitting: When the car is up on jack stands there's nothing supporting the weight of the engine and the front frame horns will droop slightly under the load. If you support the engine cross member that will usually take the problem away. Or you can just work it from on the ground.
Old Oct 28, 2019 | 08:20 AM
Chris
Allan and ken, it seems like when I shim it at the top I'm not sure it's actually pushing the bottom down and toward the front as it needs to go to clear the fan. Maybe it's bowing in the middle. Who knows. Maybe my core support is bowing up under the shroud slightly causing the shroud to be higher than it should.
Old Oct 28, 2019 | 09:17 AM
That's why I asked if you could bend the mounting tabs at the bottom of the core support. The core support shouldn't be bowed. You might have to shim the lower part where the shroud attaches to the mounting tabs too in order to move the shroud back a bit.
Old Oct 28, 2019 | 12:48 PM
Chris
So Allan are you suggesting I bend the core support mounting locations back? the first message asked if I could bend the mounting locations on the plastic shroud but your second message I think is suggesting to bend the metal core support mounting areas. Can you confirm this? I think that might work although I'm not at home so I can't exactly picture whether that's possible. Thank you!
Old Oct 29, 2019 | 07:08 AM
You won't be able to bend them much. If you had a fan shroud before you did your restoration it should bolt back in without much hassle. I'd try mounting the shroud first with the car at ride height on the ground. If that doesn't work, you can also shim the lower part of the shroud to force it further forward. I think (and I could be wrong) that your fan is hitting on the inside of the shroud? Try the shims from the top first to see if that will work. The bottom shroud mounting tabs are welded in place so they're not going to move, just the angle of the tabs will.
Old Oct 29, 2019 | 12:46 PM
Chris, one more thing comes to mind. Did you by chance change your water pump? If you did and it's a longer snout that may be your problem. There are 3 different lengths. If yours is now longer, that would account for putting the fan in a position where it might be scraping the inside of the shroud. Ways to fix: get water pump with shorter snout, or get a new water pump pulley with a deeper bell to offset the longer snout. If that doesn't make sense, PM me and I'll go through it with you.
Old Oct 30, 2019 | 10:45 AM
As far as I can tell, a clutch fan can do four things. One, spin freely. Two, be totally locked up. Three, spin about one half a revolution. Four, spin about a blade's width, like 45 degrees.
One and two means it's toast. Three means it's disengaged and cold. Four means it's hot and engaged.
Old Oct 30, 2019 | 04:32 PM
Chris
Thank you Allan. I will be looking at it this weekend so I will most likely PM you. And thank you Koda for your post. Much appreciated
Old Nov 2, 2019 | 10:10 AM
Chris
Allan, I did get a new water pump which I thought was the same size, but perhaps not. Do you know what the original distance between the radiator and the thermal clutch should be? If so, I can measure that And determine if that is my issue, or the shims are my issue. Thanks guys! Chris
Old Nov 2, 2019 | 11:18 AM
Chris, have a look at this thread. John has excellent pictures, Joe chimed in on post 7 with length measures
Water Pump Lengths
Old Nov 2, 2019 | 01:59 PM
Chris, here's something for you to reference
71-72 Olds A body
350 with A.C.or H.D. Cooling 5.95" Casting 231073 <<< I believe this is your application. Aftermarket castings may have different numbers but this gives you the length
350 w/Air Pump 5.57 Casting 231066
350 w/o A.C., H.D. Cooling, O.A.I. or Perf. Axle 5.09" casting 231065
jpc647
Dec 16, 2016 06:21 AM
lshlsh2
Apr 21, 2014 08:14 PM
ED50469
Sep 12, 2013 08:45 PM
rmoths
Apr 17, 2013 10:02 PM
oldsguybry
Nov 29, 2012 02:54 PM
