Fan Clutch Problem
Fan Clutch Problem
Went for a drive to day in the cutlass and I believe that the fan clutch seized. Was thinking it might have been the water pump. It started with a bearing type squeal above 50 mph. Noticed the fan blade was locked and the stayed locked. The car never overheated, in fact cooled down by the time I got home (165 or so). It looks easy enough to change if the MAW don't get me. Just checked again fan is very stiff and squeaks if forced after 1 1/2 hours.
Am I missing anything?
71 cutlass convertible
350 2bl carb with A/c
Thanks Larry
Thanks Larry
Thanks for confirming for me.
Now for the MAW's
Replace fan belts
Paint fan and top plate
Clean fan shroud.........pull and rebuild engine..........remove body from frame
Help someone stop me!
Now for the MAW's
Replace fan belts
