Setting Up the ILC?
Setting Up the ILC?
Can anyone tell me the correct way to set the Idle Load Compensator so it does its job correctly? I know you can twist it to drive it in or out, but what's the correct setting?
If you are talking about a CCC 307, the ONLY way to set it is per the factory adjustment process in the CSM.
