SBO gold engine paint
Old Feb 18, 2022 | 06:46 AM
rfpowerdude's Avatar
Anyone know of an acceptable gold spray bomb paint type that would be good enough to paint the 403 going back into the '70? Something I could order online (like Amazon)? Doesn't have to be perfect, just something close and will last longer than 6 months.
Thanks all!
Old Feb 18, 2022 | 07:08 AM
71OldscutlassS's Avatar
I used VHT engine enamel spray cans.
They claim to use their primer before painting, and i wouldnt add a too thick coat of paint, because the thicker the coat, the easier it can chip off due heating and cooling process.
Greetings from Austria, i hope this helps!
Old Feb 18, 2022 | 01:42 PM
cdrod's Avatar
Rodney
I used the VHT #SP404 Gold Flake on my block. I think the stock Olds color is a bit more bronze in color, but the VHT sparkles more! Here's a pic.
Rodney
Old Feb 18, 2022 | 02:06 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Your motor convinced me to go that route. It really pops compared to something like the lousy Duplicolor.
Old Feb 18, 2022 | 02:59 PM
71 OLDS's Avatar
my vote is for Fusick SBO Gold paint - 3 or 4 spray cans for a motor. Here's my son's 70 Supreme motor:
Old Feb 18, 2022 | 06:16 PM
RetroRanger's Avatar
72 Olds CS
Cdrod and 71 Olds those both look great.
i used bill hirsch olds gold, i think it looks good but its more old school doesnt look as gold as either of those pictured,
Old Feb 18, 2022 | 06:31 PM
Thanks all!
I painted mine with Duplicolor Universal Gold Engine Enamel from the local parts store. I don't remember the number as it's been way too many years, but it is close enough to factory for my needs.
https://www.duplicolor.com/product/e...-with-ceramic/
Old Feb 18, 2022 | 07:30 PM
HighwayStar 442's Avatar
[QUOTE=cdrod;1406811]I used the VHT #SP404 Gold Flake on my block. I think the stock Olds color is a bit more bronze in color, but the VHT sparkles more! Here's a pic.
Rodney
[/QUOTE
Did you clear coat over the gold?
Old Feb 19, 2022 | 03:37 AM
cdrod's Avatar
Rodney
No clear, just gold paint!
Old Feb 19, 2022 | 05:58 AM
It sure does look shiny in that pic. It is almost semi gloss or a matte finish, at least how it went on for me. The VHT Black Metallic has more shine, using it for the accessories.
Old Feb 19, 2022 | 07:02 AM
Skydog9's Avatar
Skydog9
Thanks all!
Old Feb 19, 2022 | 08:30 AM
I like that you painted nut and bolts black. I did the same thing on mine.
Old Feb 21, 2022 | 07:05 AM
Thaks for all the replies! I went ahead and ordered some POR15 gold. I'll post pics once I get it all coated. Will likely be a little more bronze-ish, but that's ok.
Old Feb 21, 2022 | 02:29 PM
rogue_ryder's Avatar
G-Body Driver
+1 on VHT over the Duplicolor.
I used the VHT Gold engine enamel on Brake Calipers of all things and they still look good 4 years later.
On my engine, I used the VHT Engine Enamel primer and then the Engine Enamel (Gloss Black) and it actually held up pretty well only spot I had some paint flake off was by the bad near the distributor of all places, I probably didn't clean that one spot it well enough. The key is all in the prep. I half assed many blocks with Refrigerator Epoxy from Wal-Mart 20ish years ago and it would hold up for about a season of racing (these were all on VW & Mazda blocks) I wouldn't prime either, and back then you could paint 2 blocks with a $2 rattle can. On my Olds I cleaned everything with acetone after I washed and degreased the block with purple power after picking it up from the machine shop. And I heated the block up with a MAP torch to get the paint to stick (this was in the winter).
The next block I do I'll be using the Rustoleom Rusty Metal Primer as the base:
olds 307 and 403
Sep 30, 2022 08:56 AM
Kensey
Apr 20, 2021 05:50 PM
Oldssupreme
Apr 17, 2020 05:59 AM
OldsW29
May 21, 2014 03:25 PM
RAMBOW
Mar 14, 2010 07:44 AM
