Edelbrock 7111 intake bolts
Old Feb 11, 2022 | 09:24 AM
1968Cutlassfallbrook's Avatar
Hello
I have been looking for a part number for the edelbrock 7111 intake bolts but haven’t found one does anyone know the part number or what bolts I need to get thank you
Old Feb 11, 2022 | 12:23 PM
I bought bolts at the local hardware store. There are two that need to be an Allen head, external Torx, or whatever the style used on headers is called, since there isn't room for a wrench to get on a regular hex bolt head. And I used thick Grade 8 hardened washers under the bolts (Grade 5 are too soft and will bend), also available at the local hardware store.
Old Feb 11, 2022 | 12:55 PM
70sgeek's Avatar
'72 Cutlass ragtop
https://oldsrocketparts.com/index.ph...fy-tunnel-ram/
Old Feb 21, 2022 | 12:39 PM
rogue_ryder's Avatar
G-Body Driver
^ those ones from Junior are probably the best option.
I purchased the 7111 from Lynn via eBay https://mondelloperformance.com/prod...old-bolt-kits/ and there's 1 tricky one that I had to grind the flange down so it would fit. I think I actually tried a socket head cap screw from the hardware store and that one location still wouldn't clear. Not sure WTF Edelbrock was thinking when they cast these.
Old Feb 23, 2022 | 06:47 AM
bigdooly's Avatar
Think I bought off Amazon bolts for 3711
Tiha
Feb 20, 2018 08:05 AM
yankees
Jun 11, 2016 07:46 PM
wcourt3010
Jun 23, 2014 12:24 PM
Tim305
May 20, 2014 05:51 PM
seok
Mar 6, 2011 08:24 PM
