rocker adjustment
Old January 25th, 2011 | 11:38 PM
JeremyTA's Avatar
rocker adjustment
whats the proper way to adjust rockers on #2 heads from a 65 330?, same process as a chebby?
Old January 26th, 2011 | 12:28 AM
64Rocket's Avatar
First, what rockers do you have?
If stock, you roll the engine until the lifters are on the base circle, and bolt them down. No adjustment.
If you have adjustable rockers, tighten until you feel tension and then 1/4 turn more.
Gene
Old January 26th, 2011 | 12:19 PM
JeremyTA's Avatar
Thanks! i'm almost positive everything is stock.
Old January 26th, 2011 | 11:52 PM
svnt442's Avatar
Torque is 25 ft lbs.
joepenoso
June 20th, 2013 06:43 AM
CutlassLegend
September 21st, 2011 03:56 PM
kaptmikey
January 23rd, 2010 12:58 PM
gibbo69olds
April 24th, 2008 01:29 PM
rickie
January 12th, 2003 12:34 AM
