rocker adjustment
Old Jan 25, 2011 | 10:38 PM
JeremyTA's Avatar
rocker adjustment
whats the proper way to adjust rockers on #2 heads from a 65 330?, same process as a chebby?
Old Jan 25, 2011 | 11:28 PM
64Rocket's Avatar
First, what rockers do you have?
If stock, you roll the engine until the lifters are on the base circle, and bolt them down. No adjustment.
If you have adjustable rockers, tighten until you feel tension and then 1/4 turn more.
Gene
Old Jan 26, 2011 | 11:19 AM
JeremyTA's Avatar
Thanks! i'm almost positive everything is stock.
Old Jan 26, 2011 | 10:52 PM
svnt442's Avatar
Torque is 25 ft lbs.
joepenoso
Jun 20, 2013 05:43 AM
CutlassLegend
Sep 21, 2011 02:56 PM
kaptmikey
Jan 23, 2010 11:58 AM
gibbo69olds
Apr 24, 2008 12:29 PM
rickie
Jan 11, 2003 11:34 PM
