rebuilt carburetor. starts and dies.
So i just got done rebuilding my carb that i picked up earlier and i've got a different problem now. When i start the car it runs for all of 2-5 seconds and dies unless i keep pumping the gas pedal. Choke is working and releases 1/8 of an inch about 2 seconds after car has started.
So what should i look for? I'm a little stumped, could it be the idle mixture screws need to be adjusted? They still have the tamper proof caps over them.
Thanks in advance for the help
do you have the filter installed correctly?
is it loading-up? or stalling lean?
did you put the float needle pull-clip through any of the holes in the float?
bill
bill
I noticed that if i held the choke plate almost all the way closed (1/8-1/4 way open) it ran great. Which i think means lean correct?
Should i drill out the idle mixture screw tamper caps and try to adjust it a little richer?
How did you rebuild it, and not remove the tamper caps and the mixture screws?
It sounds like you're not getting gas through the main jets.
Are you sure that you put the gaskets on the right way around?
Ok been up since the crack of dawn. Still cant figure this out. I tore the carb apart and checked and cleaned everything. All the passage ways are clear and i can blow air thru them. Its getting fuel as the carb bowl is full of gas and float is set at the correct level. Removed tamper caps, the idle mixture screws were at 5 turns which should be supplying plenty of fuel. I even tried taking them to 8 turns out and it still wont run on its own unless i hold the choke closed.
That seems to be the only way it'll run on its own is if i hold the choke partially closed (even on a hot engine.)
I'm running out of ideas on what to try next. any ideas guys?
I tried googling it but all that comes up is stuff about small engines like lawnmowers ect. ect.
I checked the jets and they're clear i was even able to blow air thru them so i dont think its clogged.
And i'm pretty sure the gaskets are on right I checked it when i had it apart this morning.
I only ask about the gaskets because I've done that one before, myself (though not on a Q-Jet). Took it apart at least 3 times before I finally saw that the gasket was backwards and blocking one passage.
Yeah that seems like something i'd do but checked everything and its all good. this carb is killing me. i've tried everything i could think of and still no go.
The 403 carb works but has a horrible off idle stumble which i couldnt fix, i think the carb is warped beyond repair i gave up hope on it.
The chevy 350 works but still had a little stumble and had no power, and the back barrels wouldn't open with this carb.
So far i've determined that the olds 350 carb is running too lean as if i choke the engine it runs great. but the idle mixture screw have almost no effect at enriching the mixture, not even the apt screw is enriching it enough
By throttle body do you mean the base plate that houses the idle mixture screws and the throttle plates? besides removing the idle mixture screws no i didnt disassemble it. Those throttle plate screws always break on me.
But on a positive note i did get it running it turned out to be clogged passageways a lot of flaky crap came out.
It idles good but once again I'm back to my off idle stumble issue. From a dead stop it hesitates slightly and becomes pretty shaky until the car gets moving.
And my idle mixture screws are pretty much ineffective unless their turned all the way in then the motor almost dies from lack of fuel. But no matter how many turns out it wont richen up the mixture.
And yet again my air/fuel ratio gauge is showing almost completely lean at idle.
I sprayed around the carb with carb cleaner and dont have any vacuum leaks neither
it sounds like you still have some crud in the passages of the throttle body/float bowl assembly. you may wish to try a more aggressive cleaner. glad you're making progress though.
bill
yes, that is the throttle body, above it is the float bowl assembly, on top of the float bowl assembly is the air horn assembly.
bill
bill
Guess im gonna tear the carb apart again for the 5th time today.
I'm really close to just saying the hell with it and driving the car into a tree.
Are you running a CCC Q-Jet? When I overhauled mine, I could barely get it to run at first. The odors from the exhaust plus burning eyes made me realize I was too rich. It turns out the rich stop for the M/C Solenoid was too far out. Since a CCC carb is full rich until the EMC goes into closed loop, full rich was too rich!
Hate to sound like a sheep or a lemming, but.....buy a holley and use that Qjunk for a door stop. After working with the new holly ultra HP I will never adjust another qjet again unless it's on a resto project.
I would do that but im flat broke atm. have no credit cards to use. and i'd rather get this working right, at 1 point the other quadrajet i had was working great no problems and then out of no where it started thie off idle hesitation. Plus i already dropped what little money i had into these carbs i wanna make them work so i didnt just waste all my money for nothing.
bill
I adjusted the idle mixture screws again, i'm now at a steady 19.5 in vacuum. but the screws are at 8 turns out just to get it there and according to my a/f gauge its still too lean.
But if i cover the carb most of the way and go look at the gauge its almost perfect in the ideal/rich zone.
I saw the carb dip at walmart today its b-12 chemtool brand will that be enough to dis lodge whatever is causing my problems?
Just got done cleaning the carb yet again. I even used a can of seafoam afterwards, still no go still got the hesitation, what else can i do. There gotta be something i'm missing or not doing.
Thanks but at the moment im flat broke and i already got so much time and money in the quadrajet that i'd rather just get it working right. I guess no one has anything else i can try or do to richen up the mixture and make it run right?
So the weirdest thing happened today. The hesitation went away all on its own. I put about 60 miles on the car today so maybe that helped some. Mostly highway speeds 55 and up.
Well on my way home i looked down at my a/f ratio gauge and noticed that it was riding in the ideal/rich area (instead of lean like it had been). When accelerating from a light i noticed i had no hesitation and it had all its glorious power back. I even spun the tires accelerating from a dead stop cause i wasnt used to the power.
0-60 times are better, I'm doing 0-60 in roughly 7-8 seconds now. Not bad for a 4000lb boat with a stock 350 and 2.41 rear gears.
But thanks for all the help the past couple days. i can surely say i know a lot more about quadrajet carbs. from my experience.
- broke into pieces,
- dissolved,
- got blown through, or
- lodged somewhere out of the way (but may come back).
They all work better when they're clean .
It magically cleaned itself out, no but really sometimes just driving these olds beast helps remove deposits of all kinds. Its worked for me many times and failed several other, but I wont mention at age 16 driving a 455 with 2 quarts of cheap oil would do. That was many many years ago.
This morning was the ultimate test. Took it out for a spin and it runs great, I do notice a slight hesitation on a cold engine but once it warms up to operating temp. hesitation goes away. Probably a choke adjustment needed. All in all I'm happy, and I didn't have to buy an edelbrock or holley
The car has so much pick up compared to before when i was running the computer controlled set up. Anything more then 1/4 throttle spins the tires from a dead stop. Hell i can even spin the tires from a 10mph roll . Although I do notice some pinging upon acceleration, I think the replacement vac. advance i got from advance auto gives too much advance. Now I just need to hit up the drag strip and see what my 1/4 mile time is.
Also i think i got the carb adjustments dead on. My air/fuel ratio gauge is riding in the middle of the ideal zone . My current adjustments are APT screw is 3.75 turns from seated, and idle mixture screws are at 8.25 turns, 73 jets with 55 rods cv secondary rods with H hanger.
The pics are of the carb from the JY before rebuild (wish i would of taken a pic before i scrapped all the crusty crap out. you can see some of the corrosion on the secondary rods.
#31
#32
Nice job, and I commend you for sticking with it.
I used to do the same thing years ago, but the juice just isn't worth the squeeze anymore.
CV are good rods. I have a Cigar box full of Qjet rods if you feel you need to adjust it further.
#33
Well guys just an update to the problems i been having with off idle stumble/hesitation/misfire. Its finally fixed!!!
It wasnt carb problems, it was ignition. I took the car to a garage i used to work at. And had my ex-boss take a look at it, within 2 minutes he knew it wasnt carb problems but ignition he said it was a misfire.
So first i tried new plug wires which made a little difference but still would have the hesitation on off idle acceleration just randomly now.
So today i decided i'd pull the spark plugs and check condition and gap. I regapped the plugs to .045 (it was 0.65 originally. All the plugs looked good except number 8 (pic below). It was in horrible condition looks like carbon build up or even oil fouled. Went to the store bought a new ac delco r46sz regapped at 0.45 and the car runs amazing again.
I'm guessing the valve seals in cylinder #8 are done. Or my piston rings are shot and letting oil by.
The funny thing is those plugs only have roughly 10,000 miles on them.
#34
I'm very glad you found the problem and got it running well!
The above is a far cry from this, though:
The problem that you found should not have been causing the problem you described at the outset.
That plug is icky, though.
#35
What do you mean (The above is a far cry from this, though)? is that gap too small? should i go back up to 0.60-0.65? The engine seemed to run great at 0.65 from December til July. Everything was good til I switch to non computer carb and dist.
I know the problem in the first post wasn't cause of the spark plug. That problem was the carb clogged up with crap, once I thoroughly cleaned it, it ran good but still had the off idle stumble and hesitation. Which was later diagnosed as an ignition misfire by my mechanic ex-boss.
#36
And right they are.
I mean this:
The exact gap isn't super important in this case -
You've got HEI, so in theory you can run a 0.065" gap, but in practice such a large gap isn't necessary, and running it puts an added strain on the insulation of your ignition components.
The engine was designed to run at 0.035", and so 0.035" should be fine.
If you wanted to go up to 0.045", that'd be okay, too, but you probably won't see any advantages above that.
I would say that now that you know that you've got oil in that cylinder, and that it fouls out at 10,000 miles, you should probably make a point of checking that plug every 5,000 miles or so, and cleaning or replacing it if necessary.
#37
No need to pull the heads to replace valve guide seals. It's a bit tedious, but not a hard job.
And right they are.
I mean this:
And right they are.
I mean this:
Oooo right gotcha
Yeah i guess every 2nd oil change i'll pop out number 8 and check it until i can afford to do valve seals.
I cant believe i spent all this time and money tearing down and playing with the 3 carbs i got, to find out it was a fouled spark plug in the end. I never checked them cause the passenger side is a PITA and i kept telling myself "Oh their good they only got 10k on them it cant be the spark plugs" aka lazy. Leason learned.
#38
VORTECPRO
January 29th, 2018 05:39 AM
455Olds
September 15th, 2014 08:46 PM
emarkay
November 14th, 2005 09:13 PM
