rear plug behind cam installation.
Old Sep 3, 2012 | 07:16 PM
coppercutlass's Avatar
Chevy budget Olds powered
I have never installed the rear plug that goes behind the cam bearing the machine shop usually does this when they replace the cam bearings but i did not have the plugs at the time . Whats the procedure ? How far do you install it., i cant imagine installing it untill you hit the cam bearing .
Old Sep 4, 2012 | 05:09 PM
Run to Rund's Avatar
I install it far enough that all of the shallow cup is on the straight section, leaving space to the bearing. Then I put RTV around it on the outside for extra insurance.
Old Sep 4, 2012 | 06:56 PM
SBORule's Avatar
I would take the shortblock back to the machineshop and have them install it.
Old Sep 5, 2012 | 12:03 AM
By shallo cup lined up to the straight section you mean edge of the block ? This is what I was thinkin too. Since the oil pan is not o n yet I might be able to see the space I have between it all. Next weekend I will back the cars out of the garage and start finishing it all up from where I'm at.
Old Sep 5, 2012 | 06:57 AM
442Harv's Avatar
It is a pipe thread, so it tightens as it goes in. I just snug it good and use some sealer on it. There might be a torque spec, for it ?
Old Sep 5, 2012 | 07:05 AM
380 Racer's Avatar
Thought you did everything yourself?
Old Sep 5, 2012 | 07:06 AM
no not that . Im talking about the freeze plug that really isnt a freeze plug it's the cover for the cam bearings.
Old Sep 5, 2012 | 08:07 AM
captjim's Avatar
There is no pressure on this, it just gives access to the cam tunnel. Install it just like you would a freeze plug, thin coat of sealed and press it in flush with the block.
Old Sep 5, 2012 | 08:32 AM
Thanks guys .
Old Sep 5, 2012 | 04:52 PM
I meant to drive it in far enough that the lip of the plug is just past the chamfer at the start of the hole.
ds00469
Jan 25, 2014 05:12 PM
bluecab
Apr 21, 2012 05:52 AM
benji94
May 21, 2010 10:42 AM
68conv455
Nov 11, 2009 08:05 AM
68conv455
Oct 18, 2009 07:36 AM
