Q-jet Carb
Old Aug 30, 2016 | 09:38 AM
72cutlassdog's Avatar
Q-jet Carb
I have a qjet carb and I wanted to know if the numbers under the letters NC means anything. The numbers are 3471. I know what the numbers before the NC means. I was just curious if these numbers mean anything.
Old Aug 30, 2016 | 01:40 PM
BackInTheGame's Avatar
Would that be date of manufacture: Day 347 of 1971 to go on a 1972 model year car?
Old Aug 30, 2016 | 02:49 PM
Day 347 of 1971
If I counted right, that would have been Monday, December 13.
Old Sep 14, 2016 | 07:01 PM
shiftbyear's Avatar
I believe the nc is a bit of a mystery, it is called a plant code in some literature, others say it is an inspection stamp. I've never seen an actual list of all the codes and what they mean. If anyone knows of such a list, please post. Thanks, good topic
Old Sep 14, 2016 | 07:15 PM
marxjunk's Avatar
its the pick code for the assy plant...it matches broadcast cards
Old Sep 14, 2016 | 07:44 PM
79T/A's Avatar
Does a broadcast card tell the line worker what part goes with which car? I've never heard of one before.
Old Sep 14, 2016 | 09:40 PM
No mystery at all, and I've never been able to understand what "others" say about anything.
As Mark says it's the pick code: The workers on the assembly line looked at the build sheet and picked the right part off of the right rack to be installed on the right car at the right time. In order to make it as fast and easy for them to pick the right part, almost every part had a two letter code, including such things as carburetors, engines, transmissions, differentials, springs, sway bars, shocks, and instrument clusters.
You want a list? Go look in the Assembly Manual - it lists the carburetors and their pick codes on the page where it indicated how the carburetor is to be mounted to the intake.
As above: Yes.
Old Sep 15, 2016 | 02:19 AM
shiftbyear's Avatar
Eric, thanks for the info, it really clears things up.
Skitch72
Oct 27, 2013 09:00 AM
Don R
Oct 6, 2012 09:47 AM
oldzy
Aug 29, 2010 09:18 PM
DAN76
Jul 24, 2009 09:01 AM
