Purge valve question
Old Nov 6, 2013 | 08:53 PM
Redog's Avatar
In terms of fuel I know this:
Fuel tank has a vent into the canister, which a another tube runs out towards the carb, but going into a purge valve, then into a temp controlled vacuum switch on the manifold and then into the carb.
I do not have this purge valve on my car. It was broken, cracked open so I tossed it. All I have is from the canister to the temp cotrolled vacuum in the manifold (still has the line from the gas tank to the canister)
Car runs rough.
Can I just run the hose right to the carb and remove the temp vacuum switch? I put a cap on the carb where the pruge system is supposed to go in and the car ran a lot worse, so I pulled the cap off.
Just trying to get idle back to nice and smooth, and get rid of that horrible lag in accleration
Old Nov 7, 2013 | 12:55 AM
nsnarsk65cutlass's Avatar
If you are talking about the purge valve on the '85 i replaced those in the day.It's been a long time, but i think the engine went rich when the diaphram failed.
Old Nov 7, 2013 | 06:47 AM
Then put it back to stock. The purge system is designed to only purge the canister under certain conditions. Otherwise, you are introducing a vaccum leak through the canister, thus the rough running.
Old Nov 7, 2013 | 02:28 PM
Redog's Avatar
I no longer have the purge valve.
Going to the junkyard next week, I'll see if they have one there
Old Nov 7, 2013 | 04:51 PM
OLD SKL 69's Avatar
GM Enthusiast
x2
Can get a new one reasonably prced through Rock Auto. For the money, probably better than rolling the dice on a used one and finding out if it still works.
Old Nov 7, 2013 | 05:58 PM
Redog's Avatar
OK will do.
Old one was broken anyway
1970_442
Aug 11, 2018 07:50 AM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
jpc647
Oct 12, 2012 03:11 PM
JRios
Dec 13, 2010 11:13 PM
Joeypete
Apr 5, 2010 10:44 PM
