Problems after engine swap
Hi everyone.
Last week I swaped the 260 in my 81 Cutlass for a 307
Now the car starts up fine, but dies quickly, the more gas I pump in with the pedal, the longer it will go.
I decided to take of the carb yeasterday and se if I can locate the problem, and make it look a little nicer.
So give me some ideas, what could be wrong?
And I suspect that at least one person on the forum has done this swap
Sorry for bad English// Regards Niklas
Yes, check the operation of the choke and the choke pulloffs. If the choke pulloff is not working the engine will start and run for a few seconds and then stall. You can check them with a hand held vacuum pump.
Yeah I was going to say Carb as well.
Is the choke plate shut when it stalls? If you can prop it open, just a little, doesn't have to be opened all the way, it shoudl start right up with no problems.
I just put a screwdriver in there until I start it, then pull it outr after the car starts running
I can't speak to European cars, but a US-spec 307 from that vintage WOULD have been computer controlled. These engines will NOT run correctly without changing the carb and distributor to pre-computer versions. The two things to look for are the connectors in the photo posted above and the presence or lack of a vacuum advance can on the distributor. If there is no vacuum advance can and/or the carb looks like the one above, you must change those parts.
Arrowstorm
Suspension & Handling
25
July 29th, 2015 05:52 AM
