Problems after engine swap
Old Sep 9, 2014 | 03:41 AM
Sockna's Avatar
Hi everyone.
Last week I swaped the 260 in my 81 Cutlass for a 307
Now the car starts up fine, but dies quickly, the more gas I pump in with the pedal, the longer it will go.
I decided to take of the carb yeasterday and se if I can locate the problem, and make it look a little nicer.
So give me some ideas, what could be wrong?
And I suspect that at least one person on the forum has done this swap
Sorry for bad English// Regards Niklas
Old Sep 9, 2014 | 04:41 AM
M-14's Avatar
Could it be the carb is dirty or the choke isn't working. Does the choke close when you first pump the pedal?
Old Sep 9, 2014 | 04:54 AM
Oldsmaniac's Avatar
Yes, check the operation of the choke and the choke pulloffs. If the choke pulloff is not working the engine will start and run for a few seconds and then stall. You can check them with a hand held vacuum pump.
Old Sep 9, 2014 | 03:29 PM
Redog's Avatar
Yeah I was going to say Carb as well.
Is the choke plate shut when it stalls? If you can prop it open, just a little, doesn't have to be opened all the way, it shoudl start right up with no problems.
I just put a screwdriver in there until I start it, then pull it outr after the car starts running
Old Sep 10, 2014 | 01:50 AM
Sockna's Avatar
Thanks for the help everyone
Im gonna fix up the carb before I test the choke.
Old Sep 10, 2014 | 06:16 PM
Where did the 307 come from?
Was it a computer controlled 307? If so, which carb and distributor are you using?
Old Sep 11, 2014 | 02:45 AM
Sockna's Avatar
I think it came from a Caprice 85-90,
But Im not sure, previus owner wasnt sure either.
Im using the carb and the distributor from the 307
Old Sep 11, 2014 | 04:32 AM
M-14's Avatar
Does it have these two electrical connectors?
File Type: png
Old Sep 11, 2014 | 05:47 AM
I can't speak to European cars, but a US-spec 307 from that vintage WOULD have been computer controlled. These engines will NOT run correctly without changing the carb and distributor to pre-computer versions. The two things to look for are the connectors in the photo posted above and the presence or lack of a vacuum advance can on the distributor. If there is no vacuum advance can and/or the carb looks like the one above, you must change those parts.
Old Sep 11, 2014 | 07:06 AM
Sockna's Avatar
Yes it has
So, replace distributor and carb can solve it.
chasman414
Jun 25, 2020 07:05 AM
Arrowstorm
Suspension & Handling
25
Jul 29, 2015 05:52 AM
autocomman
Aug 14, 2014 07:26 AM
hawks70
Nov 18, 2013 03:23 PM
REDROCKER-S
Oct 5, 2009 05:20 PM
