Polishing chambers on #6 heads
Old Apr 7, 2016 | 11:26 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
How many CC's can I gain and any thin spots to avoid? I am swapping heads, current set are at 55CC and fully ported. The other set are around 64-65CC, will put them on my current 350 at 9 to 1. I will get a 2.07" intake valve added in place of the 2", new valve job, any guides redone and new seals installed. Don't want too high of compression but don't want a .100" head gasket either for mid 9's on my 424 ci 403 stroker.
Old Apr 7, 2016 | 04:42 PM
80 Rocket's Avatar
Probably 3-5 ccs. Just go until any porous casting is gone. The combustion chambers are fairly thick.
Old Apr 7, 2016 | 06:31 PM
Good 5cc will definitely help.
Old Apr 7, 2016 | 08:53 PM
80 Rocket's Avatar
The dish in your valve as well as how far the valves are placed into the head will also give you more volume, or take away volume.......depending on how it is done and components selected.
Old Apr 8, 2016 | 07:06 AM
Doesn't usually adding say in my example, a 2.07"intake in place of a 2" intake valve usually make the chamber a couple of CC smaller? Where as say a valve job, reusing my 1.625" exhaust valve will added a small amount of CC's. Is this correct thinking? The valve train is adjustable, so do I just buy the Milidon or similar valves for iron heads? Any other variables?
omg_its_nickels
Care and Appearance
Apr 28, 2010 05:44 PM
nelsontj
Care and Appearance
Oct 14, 2009 03:09 PM
agtw31
Aug 12, 2009 05:53 AM
agtw31
Aug 9, 2009 08:12 AM
68Tom
Jul 24, 2009 07:50 AM
