PCV Valve troubles
Old June 27th, 2016, 07:37 PM
77ricbaez's Avatar
PCV Valve troubles
I got a replacement PCV valve, pulled out the old one (was really hard). Now, putting the new one in should be simple right? Nope, it doesn't want to go all the way in.
There it is, not all the way in but it seems to be in the hole inside the grommet.
Does this thing go in at an angle? Or do I need to be more aggressive with how I work it in. I really don't want to risk pulling the grommet out and having it collapse and fall into the hole (don' want to cause more trouble). The grommet doesn't look damaged to me.
77ricbaez is offline
Old June 27th, 2016, 08:57 PM
Hookers under Hood
76olds's Avatar
The PCV valve doesn't look like an OEM one, My original was a 90 deg valve. It must be bottoming out on the baffle. I bought an aluminum on that looks the same as OEM. You may want to find a different one.
I bought the summit racing one sum-440308 90 DEG.
Hope this helps some
Eric
76olds is offline
Old June 27th, 2016, 08:59 PM
If it looks like this it won't work:
If it looks like this its ok
Put some oil on the sides of the pcv and see if it will slide in. It may be that the grommet is old and shrank.
This is the one that Eric and I use
oldcutlass is online now
Old June 27th, 2016, 09:01 PM
77ricbaez's Avatar
hm thats weird, the old one that came out was the same one as the one thats in there right now.... maybe it was replaced before with the WRONG one. Still I wonder how they got it in there....
Old June 27th, 2016, 09:02 PM
Those grommets got awfully hard over the years, but fortunately they are readily available.
Your local auto parts store ought to be able to order one, or you could get one on line.
Dorman 42314.
MDchanic is offline
Old June 27th, 2016, 09:09 PM
77ricbaez's Avatar
ALright, I see them on the store.
Old June 27th, 2016, 09:18 PM
Hookers under Hood
76olds's Avatar
Thanks for posting the pics Eric, they certainly help out. The Dorman Grommet part number helps as well.
You guys are a tremendous help here !!
Cheers
Eric
76olds is offline
Old June 27th, 2016, 09:23 PM
77ricbaez's Avatar
Cheers
Eric
How many Erics do we have here? haha
Old June 28th, 2016, 03:08 AM
Proud Viet Nam Veteran
redoldsman's Avatar
Several and I think we just got another one recently. We are lucky to have them because these guys know a lot.
redoldsman is offline
Old June 28th, 2016, 06:05 AM
You can go into the parts store and ask for a PCV that fits a 442 or a BBC Corvette any year from 67-73. Seems there are quite a few Erics running around here.
Old June 28th, 2016, 08:09 AM
77ricbaez's Avatar
True
Old June 28th, 2016, 09:39 AM
77ricbaez's Avatar
Got the one you said and it went in snug. But now the idle is a bit rough in drive..
Old June 28th, 2016, 09:56 AM
Hookers under Hood
76olds's Avatar
Do you have a vacuum gauge ? Sounds like you'll need to adjust the idle mixture screws with the gauge or do it by ear your call . Perhaps the curb idle will need set as well.
76olds is offline
Old June 28th, 2016, 09:59 AM
77ricbaez's Avatar
Eek!
Old June 28th, 2016, 10:02 AM
Hookers under Hood
76olds's Avatar
Are you doing a complete tune -up ?
76olds is offline
Old June 28th, 2016, 10:12 AM
77ricbaez's Avatar
No I was doing maintenance. The service manual said that PCV should be replaced every 12mo
Old June 28th, 2016, 10:13 AM
Well, if your idle changed when you changed it, it was no good (either that or the new one is... ).
MDchanic is offline
Old June 28th, 2016, 10:15 AM
I generally just rinse them out once a year with gas and gently blow dry for a few years. Usually if you shake it and it rattles its good.
Old June 28th, 2016, 11:08 AM
77ricbaez's Avatar
Thumbs down
Are you guys sure its this one?
That's the one I installed and its causing my idle to be rough...
Old June 28th, 2016, 11:14 AM
That's what they look like.
MDchanic is offline
Old June 28th, 2016, 11:19 AM
77ricbaez's Avatar
strange, the auto parts store told me that this one is the one that fits a 1977 cutlass. Perhaps California uses a different PCV valve? (Darn it California with your emissions restrictions....)
Old June 28th, 2016, 11:21 AM
Hookers under Hood
76olds's Avatar
I'm wondering if the previous owner stuck the other PCV valve so deep into the baffle, then needed to adjust the carb to try and compensate. Eric & Eric will know if this happens!!
That PCV is the alternative to the 90 deg. The hose isn't bent too much then collapsing with the vacuum is it?
76olds is offline
Old June 28th, 2016, 11:26 AM
Hookers under Hood
76olds's Avatar
At this point if the car was running good, I would do what Oldcutlass mentioned. Flush it out with fuel make sure it still rattles and reuse the old one. I've never tried it but I defiantly will with my aluminium one Ill be flushing it out this weekend. Saves a bit of $$
76olds is offline
Old June 28th, 2016, 11:27 AM
77ricbaez's Avatar
No it isn't collapsing. Idk but maybe I ended up unplugging a vacuum line on accident when i was putting back the air filter. Improbable though, because I drove it yesterday and it was fine.
Old June 28th, 2016, 11:39 AM
Hookers under Hood
76olds's Avatar
Did the new one rattle like Eric mentioned ? How about the old one does it rattle ?
76olds is offline
Old June 28th, 2016, 11:42 AM
I don't know specifically about the '77s, but the PCV in the picture, with the two hose barbs, is designed to be connected in-line, between two pieces of hose.
The first one, with the flat bottom, is the one that fits into the stock valve cover grommet.
MDchanic is offline
Old June 28th, 2016, 11:48 AM
77ricbaez's Avatar
Actually I think I got the wrong one again....
http://www.autozone.com/external-eng...777_0_0_45811/
this one should be it
Old June 28th, 2016, 12:05 PM
Full-time Taxpayer
Qwik71442's Avatar
Dorman 42314.
This is likely your issue. The grommet is old you will likely just have to push the correct one in hard to get it in with the worst case scenario the grommet cracks in the process.
Qwik71442 is online now
Old June 28th, 2016, 12:41 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
The rattle test is not the end all test for a PCV. Also you should get the exact replacement PCV for the application. Not all are the same. Even though one may fit and look the same they are not all equal. The spring and valve are different for each application. This can cause drivability problems such as too much crankcase bypass causing rough idle due to lean A/F mix.
Read on....
http://mewagner.com/
http://mewagner.com/wp-content/uploa...016-p64-67.pdf
droldsmorland is online now
Old June 28th, 2016, 01:05 PM
77ricbaez's Avatar
Fixed it. Hooked up timing light and adjusted curb idle to 770rpm Park and 540-550 rpm D. The idle was a lot smoother. Also the line from the charcoal canister was unplugged, so I pushed that sucker in snugly.
I am using a duralast pcv1125DL valve.
Old June 28th, 2016, 01:52 PM
  #31
Glad you got it working.
Almond900
February 26th, 2016 02:56 AM
tgilligan
March 22nd, 2013 01:35 PM
jpc647
October 12th, 2012 03:11 PM
abram
November 10th, 2009 10:18 AM
sborruso
August 24th, 2009 07:13 PM
Quick Reply: PCV Valve troubles
