original style hose clamps - designed to bottom?
Old Jun 10, 2025 | 07:29 PM
getmygoat's Avatar
Hi all,
I purchased the original style hose clamps for a lower radiator hose from Fuscik. They seem too big and they bottom out before I can feel much resistance in the screwdriver. Just confirming these are too big? I don't suppose they are designed to bottom and when they do - they are deemed tight enough? If too big, Fuscik's catalog is wrong.
Thanks!
Old Jun 11, 2025 | 05:02 AM
BillK's Avatar
Year, make and model ? What size hose ? Which clamp ? Picture ?
Old Jun 11, 2025 | 05:27 AM
getmygoat's Avatar
Its a 76 Cutlass lower radiator hose. Their catalog claims the right clamps are 2 1/4 for the radiator end and 2 1/2 for the water pump end... but I can easily bottom out both clamps when installed. Can't move the clamp on the hose afterwords but seems like the screw should get tight before bottoming?
Old Jun 11, 2025 | 05:40 AM
BillK's Avatar
I just looked up the hose on my Carquest and Napa accounts and they both show a 1 1/2" hose ? If that is correct then the larger clamps will probably not work
Old Jun 11, 2025 | 09:05 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Hypothesis:
I have observed the exact same problem with the J shaped bypass hose on my 68.
I have OEM hoses from the 70s & 80s. They are thicker than whats available today. I'll bet the same holds true with the main hoses.
The repro dual wire clamps bottom out on themselves before getting a good interference fit on the pump and stat nipples.
I dont think the repro clamp manufacturer took this stack up tolerance miss match into account.
Ill bet the same holds true with other styles of repro clamps.
cfair
Sep 7, 2024 09:40 PM
skyhigh
Jun 7, 2020 08:21 AM
at3reg98
May 4, 2012 08:22 PM
JeremyTA
Jun 24, 2011 08:36 PM
Redog
Dec 29, 2007 09:13 AM
