Oild Galley Plugs
Old July 15th, 2013, 06:02 AM
Sampson's Avatar
Oild Galley Plugs
Another post on here has me thinking about this. I did not remove this plug before it went to the machine shop. (Did not know it was there actually). Is this something the machine shop would have removed? Something they would have put back in if they removed it?
Sampson is offline
Old July 15th, 2013, 07:01 AM
TripDeuces's Avatar
That's a question for the machine shop. No matter what they say I would still check it to see if it's there or not. The final inspection always comes down to you. Ask yourself this, would you feel comfortable just taking their word for it only to find out later that it was wrong?
Although people may have the best intentions they don't always follow through, especially when it's not their own stuff.
Yeah I'm a cynical bastage
TripDeuces is offline
Old July 15th, 2013, 07:39 AM
Chevy budget Olds powered
coppercutlass's Avatar
If the cleaned and prepped the block properly they had to take it off.
coppercutlass is offline
Old July 15th, 2013, 09:40 AM
Sampson's Avatar
I will definitely check it out before I go to crank it. It has been a couple of moths since I picked it up from the machine shop so I doubt they would remember. Engine is in the car at the body shop. I may go up there today with an inspection mirror to check it out!
Sampson is offline
Old July 15th, 2013, 10:47 AM
Originally Posted by Sampson
It has been a couple of moths since I picked it up...
Really?
MDchanic is offline
Old July 15th, 2013, 02:15 PM
Seff's Avatar
I found an inch of dried up oil in my oil galleys when I put together my newly machined engine. It was discovered way too late in the build, but it also serves as a reminder that even reputable machine shops forget stuff.
Seff is offline
Old July 15th, 2013, 04:27 PM
Yeah, Seff, that's really kind of unbelievable.
Did they ever say why they hadn't done that?
MDchanic is offline
Old July 15th, 2013, 04:30 PM
Seff's Avatar
They had a disclaimer about having to clean all surfaces.
Seff is offline
Old July 15th, 2013, 04:34 PM
Sounds un-American.
MDchanic is offline
Old July 15th, 2013, 04:36 PM
Seff's Avatar
Very.
Seff is offline
Old July 15th, 2013, 04:57 PM
Sampson's Avatar
Originally Posted by MDchanic
Really?
Yep Eric,
I'm sending moths in there with small video cameras to check the oil galley for the infamous plug Actually I can't get my fat fingers used to this iPad contraption. By the way this thread is about the oil galley plug not the oild galley plug.
Sampson is offline
Old July 15th, 2013, 04:59 PM
Sampson's Avatar
Seth, It was actually your thread that introduced me to the fact that there was even a plug in there. Thanks
Sampson is offline
Old July 15th, 2013, 07:10 PM
m371961's Avatar
I have a thing about not trusting others work. I remove everything I can from a block, send it out to be tanked then I swab out oil passages and install plugs. On my last major build, the shop asked me to let them assemble it. I asked them how long they would warrenty it. When they said they wouldn't, I told them thats why I was doing assembly.
m371961 is offline
Old November 28th, 2013, 07:07 AM
Sampson's Avatar
Ok guys, it has been awhile since I brought this up. I brought the car home from the body shop yesterday and the first thing I did was check for the plug through the dizzy hole. No plug. So this bring up 2 questions
Is there another one on the right bank I cannot see that could be missing too?
Looks to be a 3/8 or 1/2 pipe plug. What size hole needs to be drilled?
Has anyone successfully installed the plug through the dizzy hole?
As always thanks for the input.
Sampson is offline
Old November 28th, 2013, 07:35 AM
Lars's Avatar
there are 4 plugs in the back of the block, 1 is thredded and has a hole in it for lubeing the dist gear, that goes in first, and to cap that axcess hole is a frost plug. the cam has a big 2.5 inch frost plug. and on the other side is a basic pipe plug. it is very important that all these plugs are in correct. lots of shops will forget or put the wrong plugs in!!!!
out of the 2 plugs in front of the block, 1 should have a hole in it for timing chain luberication
Lars is offline
Old November 28th, 2013, 07:41 AM
TripDeuces's Avatar
.040 hole to answer the question
Old November 28th, 2013, 11:08 AM
2blu442's Avatar
There are a few threads discussing this. Some of the inner plugs can be removed with an allen head, others require a tool with a square head. Here's a thread discussing the square headed plug.
https://classicoldsmobile.com/forums...ving-plug.html
Sampson, If your sure its not there I think you'll have to remove the freeze plug on the back to access this. John
2blu442 is offline
Old December 3rd, 2013, 05:47 PM
Sampson's Avatar
Thanks for the responses guys! This was a big help. I knocked out the freeze plug and Chris (Octania) is sending me a plug. The engine shop should have caught this IMHO.
Sampson is offline
Old December 5th, 2013, 03:09 PM
Octania's Avatar
Items posted after work
Scheduled for delivery Saturday...
Thanks for the opportunity to help out!
Another similar victim:
https://classicoldsmobile.com/forums...lley-plug.html
Octania is offline
RandyS
December 26th, 2013 10:57 AM
Eightupman
January 12th, 2013 12:50 PM
RAMBOW
December 8th, 2012 08:39 AM
ATrain1
Non-Olds Engines
June 4th, 2012 12:12 PM
oldcutlass
April 21st, 2012 10:10 AM
Quick Reply: Oild Galley Plugs
