oil pump gasket ?
Old Feb 20, 2011 | 07:05 AM
knighthawk's Avatar
From: from Wisc, then Texas, then Kansas, now back to Texas,
oil pump gasket ?
'69 350, does the oil pump mounting to the block have a gasket ?
Old Feb 20, 2011 | 07:51 AM
Dave Siltman's Avatar
The oil "filter" mounting to the block does----is this what you are referring to? The "pump" bolts to the block inside the oil pan.
Old Feb 20, 2011 | 08:25 AM
Bluevista's Avatar
Registered
I only know my '71 350 and it didn't use one, '69 is probably the same but wait for a more positive answer before you go doing anything.
The oil that would leak from there if it did would would just go back into the oil pan anyway.
Old Feb 20, 2011 | 08:30 AM
panos's Avatar
Yes but if it did leak there between,the oilpressure would drop!
Old Feb 20, 2011 | 09:07 AM
InfoJunkie's Avatar
InfoJunkie
No gasket that I can remember.
Old Feb 20, 2011 | 09:12 AM
knighthawk's Avatar
well, there is no gasket in the rebuild set, and I don't see any remnents of an old one,and I'm thinkin there was no gasket., but, IF it was to leak ,,I would think it would lower the oil pressure . just want to be SURE before I put the pan on .........thanks
Old Feb 20, 2011 | 10:07 AM
Don L/442's Avatar
Looking in the '69 chassis manual it does not show a gasket as the oil pump bolts to the rear main bearing cap. Torque bolts to 35 ft. lbs.
Old Feb 20, 2011 | 10:22 AM
knighthawk's Avatar
ok, thank you !
Old Feb 22, 2011 | 02:16 PM
tonycpe's Avatar
No gasket , put mine on yesterday.
Don't forget to put the oil pump drive shaft in first.
Old Feb 22, 2011 | 03:09 PM
ELY442's Avatar
I talked to Mondello about this last year and he sold me a baffle plate that goes in between the oil pump and engine block. I also bought ARP studs for the oil pump as well.
Old Feb 23, 2011 | 05:56 PM
tonycpe's Avatar
The oil pump does not mount to the block, it mounts to the rear main cap.
The oil filter adapter mounts to the block and it does use a gasket.
Please read all the posts of this thread starting at the top.
Old Feb 23, 2011 | 06:04 PM
gearheads78's Avatar
car guy
Someone might prove me wrong but I don't know of any American motors that use any kind of gasket. Its always machined surface to machined surface.
Old Feb 23, 2011 | 07:30 PM
Redog's Avatar
When I asked this same question a few months ago, nobody knew
Old Feb 24, 2011 | 03:02 AM
Yellowstatue's Avatar
So now everyone has had a few months of winter to study and formulate an answer and show off their new found knowledge...
Old Feb 24, 2011 | 05:27 PM
ELY442's Avatar
Oops, my bad. You're right. It mounts to the rear main cap.
Old Feb 24, 2011 | 06:16 PM
car guy
We just don't like you
Old Apr 2, 2011 | 08:47 AM
1969cutlazz's Avatar
I just replaced my oil pump with a new Melling High volume oil pump and the only gasket it came with was for the bolt on pick up tube. No gasket between the pump and the rear main cap.
Al2011
Aug 27, 2025 08:30 PM
Mike H.
May 15, 2013 11:12 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
