Oil Pump Gasket?
Oil Pump Gasket?
May 6, 2013 | 07:05 AM
Mike H.
Sep 2010
Damascus, OR
Oil Pump Gasket?
Is there suppose to be a gasket between the oil pump and block in a 455?
Mike H.
Find More Posts by Mike H.
May 6, 2013 | 07:32 AM
442Harv
Mar 2007
Tracy Ca
No
442Harv
Find More Posts by 442Harv
May 8, 2013 | 06:42 PM
Octania
Dec 2011
Where's it gonna leak to, the oil pan?
Octania
Find More Posts by Octania
May 8, 2013 | 06:44 PM
ELY442
Jul 2009
Brooklyn, NY
Mondello does make a baffle plate that goes in between the oil pump and the main cap.
ELY442
Find More Posts by ELY442
May 8, 2013 | 07:53 PM
rjohnson442
Mr. Johnson
Feb 2012
Cleveland Ohio
you do need to however make sure the pick up is sealed to the pump.
rjohnson442
Find More Posts by rjohnson442
May 15, 2013 | 10:49 AM
Mike H.
Sep 2010
Damascus, OR
Thanks for the replays. I know that early Fords use a gasket on their oil pumps so I thought I would ask. Thanks
Mike H.
May 15, 2013 | 11:12 AM
L69
Oct 2011
Connecticut
No sir
L69
Find More Posts by L69
Does anyone know if this is a oil pump to main cap gasket?
Al2011
08:30 PM
oil pump gasket ?
knighthawk
Apr 2, 2011
08:47 AM
Sealant for timing chain cover gasket and oil pan gasket
dallasite21
05:37 AM
To Gasket seal or not to gasket seal?
Sixoh
05:11 AM
looking for some clarification on 455 block manufacture year.....
01:52 AM
