Oil filter housing - must remove exhaust manifold
Old Mar 2, 2024 | 02:11 PM
getmygoat's Avatar
Hi all,
Considering swapping in a new oil filter housing gasket (olds 350). Looks tight with the exhaust manifold. Anyone know if I can swap this w/o removing exhaust manifold? Its a 76 cutlass, has cross over pipe and head pipe plumbed to that right side exhaust manifold.
Thanks!
Old Mar 2, 2024 | 07:04 PM
You should be able to access the three bolts without removing the manifold. I would start by unscrewing the filter and removing the torque converter dust cover to improve access. That 1976 manifold isn't doing you any favors. You might also consider removing the strut that runs from the frame to the crossmember on that side.
Old Mar 4, 2024 | 07:29 PM
getmygoat's Avatar
Thanks for your insights.... Guess I'll just have to dive in and learn as I go.
PaulWinn
Jan 18, 2023 06:51 AM
67cutlassguy
Jun 10, 2018 06:12 PM
srholt45@gmail.com
Sep 30, 2016 05:56 PM
Col Wickham
Dec 13, 2009 06:30 PM
67_cutlass_s
Sep 8, 2007 02:49 PM
