No oil coming to rockers
Old May 7th, 2012, 06:05 PM
Finn5033's Avatar
I dropped a used 350 in my cutlass last week and got it fired up tnite. I don't have any thing hooked up to it yet so I only ran it for about 10-15 sec. I have an oil pressure gauge and am reading good oil pressure. I loosened the compression ftg at the gauge connection and had oil spitting out. Point being the oil pump seems to be working well. I am not getting oil up to the rockers though. I only idled the engine, did not rev it up at all. Do i need to get the radiator hooked up and get some coolant to her and let it run longer and rev it up to get that oil up there? Or do I have a problem? The engine is very clean and the oil is new. Any thoughts would be great. Thank you
Finn5033 is offline
Old May 7th, 2012, 06:42 PM
Sounds normal to me. Olds motors do not spit oil from the rockers like motors from a certain other division that starts with a "Ch" do. It oozes out slowly.
A few seconds of running won't be enough to get it up and out the top.
MDchanic is offline
Old May 7th, 2012, 06:56 PM
Lady72nRob71's Avatar
It took several (5-10) minutes for mine to start oozing! Yes, I was scared, too but it takes a while for the air to purge.
I would not rev it much until oil does show up. Once one starts oozing,t he rest should follow.
Lady72nRob71 is offline
Old May 7th, 2012, 07:31 PM
Finn5033's Avatar
Ok that is what I was hoping to hear. I will get the rest buttoned up, pour some oil over the rockers and let it run for a while then. Thanks
Finn5033 is offline
Old May 7th, 2012, 08:01 PM
Here are my comments when I went through that...
https://classicoldsmobile.com/forums...tml#post325765
5-10 minutes should be enough time.
Old May 7th, 2012, 08:25 PM
Tony72Cutlass'S''s Avatar
That's exactly the time it takes for my valve train to stop being bloody noisy!
I started her up for the first time after the winter, MAN did it sound dirty. I got worried. But 5-6 minutes after idling, she finally quieted down.
Tony72Cutlass'S' is offline
Old May 8th, 2012, 07:55 AM
'87 Delta 88 Royale
rustyroger's Avatar
I fired up a friends '68 Rambler Rebel 290 engine yesterday after a rebuild (rebore, crank grind, new cam & lifters, the whole works), it took less than a minute for the lifters to go quiet and plenty of (15w-40) oil to get to the valvetrain.
5-6 minutes to pump up lifters sounds a bit long to me.
Roger.
rustyroger is offline
Old May 14th, 2012, 06:17 PM
Finn5033's Avatar
Put the radiator back in so there was coolant to the engine. After running for a couple of minutes the oil started coming to the lifters. Good feeling
Finn5033 is offline
Old May 15th, 2012, 05:20 AM
Yes! I know that feeling well!
Old May 15th, 2012, 05:53 AM
brown7373's Avatar
Did you prime the engine first? I have not rebuilt an Olds engine, but I think it would be the same as a Pontiac or Ford. I use an old distributor shaft in a 1/2 reversable drill to spin the oil pump shaft and prime the engine before startup. Put a piece of heater hose over the end of the old shaft and extend it past the end of the shaft. That wat it acts like a collar and holds the old distributor shaft in the slot in the oil pump shaft and you can run the pump with the engine off. Again, I assume it is the same for an Olds and runs in reverse.
brown7373 is offline
72Blazerod
January 1st, 2015 10:04 AM
cluelesscutlass
December 17th, 2011 01:44 AM
yopester
November 18th, 2010 09:46 PM
olds4life
March 21st, 2009 04:45 PM
Quick Reply: No oil coming to rockers
