New Engine Mount Questions
Old Mar 17, 2021 | 12:49 PM
coled18's Avatar
Hey all. Will be pulling my motor (350 rocket) on the 72 cutlass soon to replace the gaskets and do some upgrades. I've noticed that my oil pan looks like it is making slight contact with my cross member so I am assuming I need new engine mounts. If I replace the engine mounts will I have to replace the transmission mount as well? My concern is that the engine will sit higher and I wont be able to connect the bolts that connect the flex plate to the torque converter.
Old Mar 17, 2021 | 01:16 PM
The trans mount is a pivot point. The trans can rock up and down to align with the engine. Your concern is not a real issue.
Old Mar 17, 2021 | 03:19 PM
coled18's Avatar
phew that makes a lot of sense, and takes care of a concern! Thank you much and hope you have a good day sir.
Old Mar 17, 2021 | 04:30 PM
RetroRanger's Avatar
72 Olds CS
I will say my 72s engine mounts were whipped as well. When i replaced them one was broken and they appeared to be original. Based on those findings i replaced the trans mount as well. FYI its much easier to replace the trans mount than the engine mounts.
Old Mar 17, 2021 | 08:10 PM
coled18's Avatar
Thanks. I might end up upgrading my torque converter while Im down there as well.
Old Mar 18, 2021 | 06:17 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Upgrading the torque converter definitely helps launch. The stock TH350 converter flashes at 1600 rpm, pretty low. Look at the Supercars Unlimited motor mounts, supposedly a different source for them. The cheap Anchor brand mounts, at least the 73 and up style have had some with the holes way off and need them wallowed out to even bolt to the block. I haven't seen any issues on here with the 2261 Anchor mounts you need.
Old Mar 21, 2021 | 09:51 PM
coled18's Avatar
Yea I've heard stock TC stalls at around 1600 RPM, I got a torque converter for 2000-2200 RPM coming in a few days so that should be nice paired with the other stuff I am doing to the engine.
oldsmoboogie
Nov 26, 2019 02:47 PM
Gauchobyte
May 27, 2017 03:44 AM
Oldsragger
May 7, 2015 10:19 AM
foo
Apr 10, 2014 01:29 PM
rtpassini
Mar 3, 2010 06:23 PM
