Need an ID on this part, please.
Old Jun 4, 2013 | 10:39 AM
VinMichael's Avatar
So I got this engine pretty much put together, and I find this on my tool box...oops. Pretty sure it goes around the crank somewhere, but totally forget where exactly.
Here's the engine, excuse my mess on the floor
Old Jun 4, 2013 | 10:49 AM
1970-W30's Avatar
It goes on the crankshaft, right in front of the timing gear..... it's called an oil slinger and also helps to deflect oil from front seal.....
Old Jun 4, 2013 | 10:53 AM
VinMichael's Avatar
It's sandwiched between the harmonic balancer and timing gear?
Old Jun 4, 2013 | 10:57 AM
70Wcars's Avatar
Well..yes, but behind the Timing cover. So technically between the Crank Sprocket and the Oil Seal in the Timing Cover. But I have run engines without that piece with no problems from Oil leaks or " Dry " timing chains.
Danny
Old Jun 4, 2013 | 11:00 AM
VinMichael's Avatar
I remember now...thanks. At this point it would be nice to leave it out.
Old Jun 4, 2013 | 11:36 AM
boese1978's Avatar
Are these in / supposed to be in all olds engines? There was not one in my 68 350....just the cam shaft slinger....
Old Jun 4, 2013 | 12:18 PM
Seff's Avatar
That's not a messy floor, good sir. I'll show you a messy floor when I get back to my workshop.
Old Jun 4, 2013 | 02:43 PM
Yes.
And there is no "camshaft slinger" because the cam doesn't penetrate the front cover. There IS a fuel pump eccentric on the cam, however.
And technically, the slinger IS sandwiched between the crank gear and the balancer - the hub of the balancer passes through the front cover seal and clamps clamps both the slinger and the crank gear against the front bearing boss on the crank.
Johnny Cage
Feb 19, 2013 11:49 AM
IZAOLDS
Aug 9, 2010 08:36 AM
kjr442
Feb 22, 2010 06:45 AM
Texas Jim
Ninety-Eight
17
Dec 30, 2009 06:28 PM
deweirdt
Jul 21, 2009 08:29 AM
