mr gasket head gaskets
Old Oct 25, 2011 | 02:40 PM
coppercutlass's Avatar
Chevy budget Olds powered
anyone ever use the mr gasket head gaskets. i have always used felpro but with my next short block im building it seems their head gaskets will work better than the felpro's as they are a bit thinner. It will be right at 10 to 1 compression. im just curious if anyone had any experiences with them.
Old Oct 25, 2011 | 03:31 PM
The problem with mr gasket head gaskets is they are going to reduce your compression ratio. I would try and go with steel shim gaskets if your going for performance!
Old Oct 25, 2011 | 03:45 PM
even with a .040 head gasket ill be at 9.9 to 1 compression. with the mr gasket ill be at 9.95 to 1 . My new combo is gonna be a 425 piston 350 combo. I just want to get as much compression as possible and since the mr gasket set has a bit thinner head gasket and is 10 dollars cheaper im wondering if it's worth it quality wise.
Old Oct 25, 2011 | 04:28 PM
You'd be over 10 with the steel gasket! Get with these guys!
http://www.gasketcity.com/
Old Oct 25, 2011 | 04:31 PM
cutlassefi's Avatar
I use the Mr. Gasket Ultra Seals for virtually everything, no issues ever.
Old Oct 25, 2011 | 04:38 PM
thanks for the site. I want to keep it around 10 to 1 just to stay pump gas friendly.
lluebke
Apr 28, 2012 05:06 AM
Dan Wirth
Sep 1, 2009 07:13 PM
smcurro
Feb 11, 2009 08:47 PM
deltathunder
Jul 21, 2008 08:10 PM
Deltarocket
Jun 5, 2007 06:54 AM
