Motor mounts?
Old Feb 7, 2020 | 12:14 PM
EsoWuhn's Avatar
Motor mounts?
Going into the freshening up on my engine in a few weeks and beginning to gather my parts...does anyone have any good solid motor mount recommendations ? Ive checked Rock Auto/Jegs and all, and wanted to go with energy suspension; but one of their reps told me they don’t make motor mounts for the Oldsmobile 350. So I thought maybe one of my fellow Olds Owners would have a suggestion or two...thanks in advance !
Old Feb 7, 2020 | 12:36 PM
Rocket racing sells them.
https://shop.rocketracingshop.com/RO...OTOR-MOUNT.htm
Old Feb 7, 2020 | 01:23 PM
RandyS's Avatar
Geez, are they made of onobtanium???
Old Feb 7, 2020 | 01:45 PM
myhoney's Avatar
Mondello sells solid mounts, they add about an inch to the height for more header clearance.
Old Feb 7, 2020 | 01:46 PM
Yeah they ain't cheap. A lot of people take a rubber mount, drill a hole through them and put in a bolt and a stover nut.
Old Feb 7, 2020 | 05:14 PM
RandyS's Avatar
Unless I am missing some important part, it looks like you could make your own (if you can weld) for under $20.00.
Old Feb 7, 2020 | 07:47 PM
WTH? That would most likely put the fan into the top of the shroud. Correctly designed headers should fit without needing the engine to be raised an inch.
Old Feb 10, 2020 | 02:59 PM
EsoWuhn's Avatar
i was looking into that option, unfortunately i don't have a welder and cant weld yet. Even with my build, i’m doing it based off what i can find online, my manual, and the maybe two people around that can offer help. But i found some on rockauto, so for now i’ll be going that route. But thank you !
Old Feb 11, 2020 | 06:04 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Here, $100 cheaper.
https://store.dickmillerracing.com/enginemounts.aspx
1971raresx
Aug 18, 2016 08:22 AM
74 fastback
Oct 5, 2015 05:29 PM
madmax442
Apr 14, 2015 05:46 PM
csouth
Apr 10, 2012 02:19 PM
gabe442
Non-Olds Engines
Dec 1, 2011 11:19 AM
