Mechanical advance
You'll find Moroso and Crane brands pretty common. Be prepared to do a lot of testing with different springs. Timing adjustments, etc.
Don't be surprised if an adjustable vacuum advance can help out on the road to a perfect tune. Sometimes there is a little more to it.
A bit of info I learned about the Moroso HEI kit is that it's center bar and weights give 24* of mechanical advance whereas most factory HEIs have 14* mechanical advance. This worked well for me since my original points distributor had 24* mechanical advance, so I didn't have to change the initial. All I had to do was experiment with springs to get the curve where I wanted it. I ended up using one light and one medium spring.
MDchanic
October 4th, 2010 07:40 AM
