Mechanical advance
Old Jun 7, 2014 | 10:43 AM
Tedisthebestkingintheworl's Avatar
Mechanical advance
Do they make a different set of springs for an HEI distributor or would they even do any good?
Old Jun 7, 2014 | 11:20 AM
Google HEI mechanical advance kit
Old Jun 7, 2014 | 12:45 PM
What is it that you are trying to accomplish? Is your engine modified? There are different kits for different some HEI's also.
Old Jun 7, 2014 | 01:26 PM
don71's Avatar
same but different
You'll find Moroso and Crane brands pretty common. Be prepared to do a lot of testing with different springs. Timing adjustments, etc.
Don't be surprised if an adjustable vacuum advance can help out on the road to a perfect tune. Sometimes there is a little more to it.
Old Jun 7, 2014 | 06:33 PM
A bit of info I learned about the Moroso HEI kit is that it's center bar and weights give 24* of mechanical advance whereas most factory HEIs have 14* mechanical advance. This worked well for me since my original points distributor had 24* mechanical advance, so I didn't have to change the initial. All I had to do was experiment with springs to get the curve where I wanted it. I ended up using one light and one medium spring.
WTony
Jun 29, 2013 05:11 AM
DasBaldDog
Mar 1, 2013 10:20 AM
olds 307 and 403
Jul 24, 2012 05:09 PM
MDchanic
Oct 4, 2010 07:40 AM
The Stickman
Feb 19, 2009 01:23 AM
