Vin Decoder
or
Login with Facebook
Lower radiator hose rubbing - '72 Cutlass
May 13th, 2016, 10:11 AM
ddd777
Lower radiator hose is rubbing rubbing against a bolt in a way that looks like it will chafe and tear (see image).
It is a quality reproduction (so supposed to be correct length for 72 Cutlass)
Is the solution the obvious one, to simply cut it down a little?
ddd777
Find More Posts by ddd777
May 13th, 2016, 10:36 AM
My442
Push the end on the water pump in about 2", and you will have clearance.
My442
Find More Posts by My442
May 13th, 2016, 10:49 AM
ddd777
Quote:
Originally Posted by
My442
Thanks. I'll give that a try.
ddd777
May 13th, 2016, 11:50 AM
droldsmorland
CH3NO2 LEARN IT BURN IT
And or trim the end off. Pump side...
droldsmorland
Find More Posts by droldsmorland
1964 Jetstar lower radiator hose
belairbob
September 27th, 2012
07:09 PM
Lower Radiator Hose Diameter 1070 Cutlass?
matviar
April 9th, 2012
12:56 PM
Lower radiator hose
radioburningchrome
October 7th, 2009
05:11 PM
lower radiator hose on 330ci
jdanieljones
December 28th, 2008
01:55 PM
Molded lower radiator hose
harleyrules
November 25th, 2007
07:22 PM
Help with rocker studs
Posting Quick Reply - Please Wait
Quick Reply:
The following errors occurred with your submission
Okay
Quote message in reply?
08:15 AM
