Lower radiator hose rubbing - '72 Cutlass
Old May 13, 2016 | 10:11 AM
ddd777's Avatar
Question Lower radiator hose rubbing - '72 Cutlass
Lower radiator hose is rubbing rubbing against a bolt in a way that looks like it will chafe and tear (see image).
It is a quality reproduction (so supposed to be correct length for 72 Cutlass)
Is the solution the obvious one, to simply cut it down a little?
Old May 13, 2016 | 10:36 AM
My442's Avatar
Push the end on the water pump in about 2", and you will have clearance.
Old May 13, 2016 | 10:49 AM
ddd777's Avatar
Thanks. I'll give that a try.
Old May 13, 2016 | 11:50 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
And or trim the end off. Pump side...
belairbob
Sep 27, 2012 07:09 PM
matviar
Apr 9, 2012 12:56 PM
radioburningchrome
Oct 7, 2009 05:11 PM
jdanieljones
Dec 28, 2008 01:55 PM
harleyrules
Nov 25, 2007 07:22 PM
