Interference
Old January 19th, 2019, 04:56 PM
Kyle
87Brougham's Avatar
Interference
Can't seem to get these bolts in for the life of me! Edelbrock 7111. Seems that the bolt head is interfering with the plenums and it can't even be positioned into place to be tightened. Anyone else had this problem? Techniques?
(Standby, trouble with pictures)
87Brougham is offline
Old January 19th, 2019, 04:58 PM
Kyle
87Brougham's Avatar
Old January 19th, 2019, 05:18 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
The back one should go. The intake comes with a special 12 point, small head bolt for the front one you are having issue with. You can get two of them to fix them both.
olds 307 and 403 is online now
Old January 19th, 2019, 05:19 PM
Looks like you will have to use those allen head bolts, (Forget their proper name) Apparently the edelbrock manifold is too tight to use the stock bolts....
Greg Rogers is offline
Old January 19th, 2019, 05:20 PM
Kyle
87Brougham's Avatar
Oh, okay. I bought it used on eBay a couple months back. Thanks for the heads up!
Old School Olds
tru-blue 442's Avatar
Make sure you start them all 1st before making any tight.
tru-blue 442 is offline
Old January 19th, 2019, 07:43 PM
They are called Socket Head Cap Screws
The 12pt Flange bolt per the suggestion above
oldcutlass is online now
Old January 19th, 2019, 07:58 PM
I used the 12 point flange bolts shown above. And Grade 8 thick washers. Don’t use regular Grade 5 as they will deform.
Fun71 is offline
Old January 20th, 2019, 02:07 PM
Kyle
87Brougham's Avatar
Thank you all for your replies, I will have to find these online or call Edelbrock.
Old January 21st, 2019, 06:21 AM
edzolz's Avatar
It might be the angle of the pic but it looks like the rear bolt is crooked. Make sure it isn't cross threaded before tightening it.
edzolz is offline
Old January 21st, 2019, 06:54 AM
Texas69's Avatar
Bolts
Edelbrock sells a bolt kit for intake manifolds that includes the specialty bolts discussed above. While a bit overpriced, they are nice and shiny, and more importantly, they fit. May be worth looking into.
Texas69 is offline
Old January 21st, 2019, 10:57 AM
Or do like I did and go to your local hardware store and buy two bolts for those positions.
Fun71 is offline
Old January 21st, 2019, 12:48 PM
72 Olds CS
RetroRanger's Avatar
I had to turn down the head of a socket head cap screw to fit.
RetroRanger is offline
Old January 21st, 2019, 02:24 PM
shiftbyear's Avatar
Another thing to remember is most factory torque values are with the bolts oiled. I believe the intake manifold also has a torque sequence just like the heads. It may make a difference in getting a good seal. Good luck.
shiftbyear is offline
Old January 21st, 2019, 03:09 PM
You might try a local bolt and fastener store in your local area to find some.
Old August 6th, 2019, 02:27 PM
Kyle
87Brougham's Avatar
Will this affect the integrity of the screw? Got the socket head screws but having the same problem with the head getting pushed by the runner.
Old August 6th, 2019, 03:47 PM
72 Olds CS
eh probably to some extent, but i didnt affect my application. I ran that intake for two tears before switching to BBo
Old August 6th, 2019, 04:18 PM
Not enough to count for a 25 ft/lb fastener.
twintracks
April 30th, 2014 09:41 AM
delta88_frankfurt
November 3rd, 2012 03:06 PM
stlbluesbrother
June 15th, 2012 08:45 AM
GTA_doum
May 18th, 2012 02:36 AM
projectheaven
June 29th, 2011 07:12 AM
Quick Reply: Interference
