Intake manifold plugs, heater core and vacuum
Old Sep 22, 2021 | 03:23 PM
HarrySlother's Avatar
i need a new heater core plug for my intake manifold (edelbrock) because i cant get the old one out of my old intake. i also need a vacuum plug for the transmission vacuum line, the old one was to small. anyone know where to find these? or what sizes they are, the heater core one is the one in the back passenger side and the vacuum is on one of the runners behind the carb. also i need a new oil pressure fitting/sender thing, machine shop messed mine up taking it out, i dont even know what the proper terms are fo these so im having a hard time googling them. thanks
Old Sep 22, 2021 | 03:42 PM
Oldsmaniac's Avatar
Pictures may help.... the oil pressure switch, sender, sending unit should be easy to find.
Old Sep 22, 2021 | 04:18 PM
FYI, the heater hose fitting needs a restriction (1/4" hole) to reduce the fluid flow, otherwise the heater core will balloon and burst. AC cars have a vacuum controlled valve that has a restriction, and OEM hose nipples for non-AC cars have a restriction as well.
Old Sep 22, 2021 | 05:51 PM
RetroRanger's Avatar
72 Olds CS
if your just looking for plugs you can find them at your hardware store NPT threaded pipe plugs.
or check edlebrocks site
https://www.edelbrock.com/socket-hea...ty-8-8052.html
Old Sep 23, 2021 | 06:10 AM
David Sloop's Avatar
Warning! Do not use steel plugs or fittings in an aluminum intake! Previous owner did this, and I ended up cracking the intake trying to get the plug out.
Old Sep 23, 2021 | 06:18 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Use antiseize on any plug or use aluminum or brass plugs. Yes the steel can seize. I am going remove the steel plumbing adapter for the heater hose, since this motor will see over 5000 rpm and going with the reduced factory adapter, it could be fun.
Old Sep 23, 2021 | 07:48 AM
NTXOlds's Avatar
Can you please post a photo of the vacuum controlled valve? When I replaced my factory 2bbl intake in my AC car with an Edelbrock 4bbl I installed a new brass fitting at the back of the engine. I have not had an issue yet, but I also don't run it at high RPMs. My old manifold seemed to have just a straight pipe as well without a vacuum controlled valve (see photos below), although the service manual seems to show that it should have one.
Old Sep 23, 2021 | 08:00 AM
VC455's Avatar
Barely Registered
Originally Posted by HarrySlother
i need a new heater core plug for my intake manifold... i cant get the old one out of my old intake.
I had problems with getting steel fittings out of both a cast iron and a very rare aluminum intake.
At the time, I worked at a manufacturing plant and one of the maintenance staff heated the manifolds with an acetylene torch, cooled the fittings with oil, and popped them out.
He used the appearance of the aluminum as a gauge to avoid getting too close to melting temperature. I admit I was worried on that one.
Perhaps you can find someone at a repair shop who has similar skill.
Old Sep 23, 2021 | 10:02 AM
Coincedently, I have mine here at work. Going to be borrowing shops tools to clean up and re-tap the port that got destroyed when I removed the steel plug from my intake.
Old Sep 23, 2021 | 10:11 AM
NTXOlds's Avatar
Thanks, David! I appreciate you posting that photo.
I definitely don't have that, but it looks like I should. I will look into purchasing one.
Old Sep 29, 2021 | 02:15 PM
This is what I'm looking for. Not sure what size it is. It's bigger than the plugs that came with the Edelbrock kits
Old Sep 29, 2021 | 03:01 PM
72 Olds CS
IIRC mine was 3/4 NPT but you may need a combination of different size adapters to get it to the size that fits.
are you trying to plug the port or find use a similar fitting on the edlebrock?
I just plugged my edlebrock port as i bypassed the heater core.
Old Sep 29, 2021 | 04:23 PM
I'm looking to get something similar to what is the picture, I might just get a plug for now so I can break in the motor and then I'll also know what size it is
Old Sep 29, 2021 | 04:38 PM
72 Olds CS
https://www.ebay.com/itm/20158582218...SABEgIRwvD_BwE
IDK if this is for your application
Old Sep 29, 2021 | 05:08 PM
That looks like it. I'm gonna give them a message and see for the exact one. I appreciate it! Couldn't find them anywhere
Old Sep 30, 2021 | 04:46 AM
It is 3/4npt... I just re-tapped min out after damaging it getting the steel plug out...
Did I mention not to use steel plugs or fittings? LOL
BTW... From what I understand, this specific part is for A/C cars. If you don't have A/C you don't need the switched valve.
There is a restrictor in the fitting, though that you still need, so you can't just find a fitting at Lowes and use it. You'll flow too much thru your heater core if you do that.
Chuck Cole
Nov 8, 2019 03:28 PM
Louglutz
Vista Cruiser & Wagons
Nov 1, 2018 06:29 PM
RocketDevo
Sep 24, 2012 12:23 PM
zodiacblueS
Sep 26, 2011 07:25 AM
