Heater Help
Heater Help
I just purchased a 68 Vista Cruiser 350 a/c car. Everything works but the heater. The blower motor blows for the a/c defroster and vent on all speeds but no hot air. When heat is selected the blower motor doesnt even come on. Any help?
I think you have a problem with a vacuum hose or the heater control valve in the intake manifold is not working. I don't have any info on '68 models but I do have something for the '69 models. I have attached a pdf from the '69 assembly manual that show the vacuum hoses for the AC controls. I would test the following items first:
1. Test the vacuum tank on the firewall to see if it has vacuum from the engine, and that it will hold a vacuum.
2. Check the watervalve at the back of the intake manifold to see if it has vacuum.
Happy hunting!
Happy hunting!
The very first thing to check is, do you have the correct heater control valve? The 1972-earlier A-body cars use a valve that is normally closed and opens when vacuum is applied. The 1973-later A-body cars use a valve that is normally open and closes when vacuum is applied. As with many Oldsmobile replacement parts, most of the aftermarket catalogs have these listed incorrectly. Even if you do have the correct valve, it is not uncommon for the valve to corrode and stick. Finally, if you are not getting air routed correctly, it is likely due to incorrect vacuum hose connections or low vacuum in the system. This will ALSO prevent the heater control valve from opening, causing the temp problem.
Vacuum leak to the heater control valve. Thanks for the help! I've never had a heater blow cold before with everything else working fine so I learned a lot about heater control valves just from these replys.
