Intake Manifold Issue Olds 324
Old Apr 3, 2022 | 07:23 PM
Navyman53's Avatar
Hey Folks,
I bought a 1955 olds super 88 4 door parts car for the engine and trans. The engine, a 324, was missing the intake manifold / Carb which I recently purchased and although the person said it came from a 324 it seems to be bottoming out on the valley pan. Also theres a little hole on the part of the intake thats hitting the valley pan. Is there a spacer that I'm missing or is this the wrong intake. Casting number on the intake is 567184 with the number 2 below it. The firing order on it is 18736542. My engine casting number is 563922 with a number 5 above it. Other numbers/letters CFD 274. Any help would be greatly appreciated.
Jesse
Old Apr 4, 2022 | 01:06 PM
2blu442's Avatar
I pulled the red intake from a 1954 324 engine. Then the green one I've been told is from a 303. Note the underside of each. Does yours look like one of these two? John
Old Apr 4, 2022 | 01:07 PM
2blu442's Avatar
Can you share some pictures with us, of the intake and the valley pan?
Old Apr 4, 2022 | 01:28 PM
Navyman53's Avatar
Intake pictures
Old Apr 4, 2022 | 01:32 PM
Navyman53's Avatar
Valley pan
This one is from a 59 394 but its a little wide.
Old Apr 4, 2022 | 01:37 PM
Navyman53's Avatar
Originally Posted by navyman53
this one is from a 59 394 but its a little wide.
Old Apr 4, 2022 | 01:39 PM
Navyman53's Avatar
Old Apr 4, 2022 | 09:03 PM
Charlie Jones's Avatar
Phantom Phixer
The manifold you bought is a 1956.
They changed the exhaust crossover in 1956 and it protrudes deeper down.
As a consequence, the block top cover was re-designed with a depression in it.
Your engine is either a 1954 or 55.
You will need to get either a 54 or 55 manifold or a 1956 top cover.
The 1959 cover is wider because the block deck height increased in 1957 with the 371.
Old Apr 5, 2022 | 03:58 AM
Navyman53's Avatar
The manifold you bought is a 1956.They changed the exhaust crossover in 1956 and it protrudes deeper down.As a consequence, the block top cover was re-designed with a depression in it.Your engine is either a 1954 or 55.You will need to get either a 54 or 55 manifold or a 1956 top cover.The 1959 cover is wider because the block deck height increased in 1957 with the 371.
​​​​​​​Thanks for the info I really appreciate it. Looks like I'll be on the hunt for either or. ​​​​​​​jesse
Old Apr 12, 2022 | 06:52 AM
Navyman53's Avatar
​​​​​​​I was lucky enough to find the correct valley pan.​​​​​​​Woo hoo. Thanks for all help.
66ragtop
Sep 24, 2017 03:22 PM
66ragtop
Sep 24, 2017 03:00 PM
manny72supreme
Dec 7, 2013 06:04 AM
grindlecrew
May 6, 2013 05:12 PM
ajohm
Aug 25, 2012 07:39 PM
